Old 12-Jan-2014, 6:26 PM   #1
Charlie84
need help with antenna selection
http://www.tvfool.com/?option=com_wr...5b94e95fff978e
being researching and googling trying to find information in which I am comfortable
have been reading posts here off and on..all of you seem to be above my paygrade in information
my house is wired with a direct tv dish and it works..but dont want the expense
any help will be appreciated
would like to get
abc-kspr
cbs-kolr
nbc-kytv
krbk-fox
Charlie84 is offline   Reply With Quote
Old 12-Jan-2014, 8:42 PM   #2
Your stated goals are doable. I would suggest you be prepared to place as much or more importance on the location of your antenna(s) as the choice of antenna. The antennas(s) will need to be up in the clear, unobstructed by nearby trees and buildings including yours.
I would consider using a tripod and 10' mast at the peak of the roof. However I would want to prove I had a usable signal before drilling into the roof.
Consider the combination of the Antennas Direct DB8e (UHF) + Antennacraft Y10713 (High-VHF) + RCA TVPRAMP1R (preamplifier).
Point the Y10713 at 340° (compass) to see real CH 10 & CH-13 (CBS & PBS).
Though they can be adjusted to aim in different directions, start with the DB8e panels facing the same direction. Face the array toward 330° approx. adjust both aim and panel alignment to maximize your reception.
Per rabbitears.info, http://www.rabbitears.info/market.ph...n=KWBM#station KWBM simulcasts KRBK (Fox).
Old 13-Jan-2014, 12:48 AM   #3
Charlie84
thanks..to summarize your post
i can "possibly" get 3 of the channels with the uhf db8e
and you think the Y10713 is strong enough (using only the theory that it does NOT cost a lot compared to other long range antennas)
i have looked at other antennas in neighborhood and they all appear to bigger versions of theY10713 looks like a "winegard" monster
about to search this forum for info on preamp's
i just like to research a lot before i invest
Old 13-Jan-2014, 3:28 AM   #4
95% of the reception information provided here at tvfool.
Is Basic Antennas and Reception information.
And is not above pay grade.
We here in the USA and Canada are now 2 generations removed from a time when the only way to receive Tv was with a Tv antenna.
And Many People had a Basic knowledge of Broadcast Tv Reception , What antenna or antennas to use for the area of reception and where the Tv transmitters are located.
_________________________________
For reception of your channels list.
KSPR , ABC and The CW.
KOLR , CBS.
KYTV , NBC.
KWBM , Daystar and Digital sub channel , FOX.
Install a , http://www.antennacraft.net , HBU44 antenna Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception , in the directions of , North West , West , South East , North East.
Aim the HBU44 antenna at about 330 degree magnetic compass direction.
As always the starting antenna aim direction is the --->starting antenna aim direction.
The antenna aim direction and the location of the antenna can be adjusted for best reception.
Most Digital Tv's have a , Signal Strength Meter , and some digital Tv's also have a , Signal Quality Meter.
Install a , RCA , TVPRAMP1R , preamplifier.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
http://www.antennacraft.net.
http://www.amazon.com.
http://www.solidsignal.com.
http://www.ronard.com.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal search box or buy from , http://www.ronard.com.
In addition to your channels you have requested , also be looking for.
KOZL , Independent Tv Station.
KOZK , PBS. Ozark Public Broadcasting.
K26GS-D , http://en.wikipedia.org/wiki/K26GS-D.
COZi Tv , Antenna Tv , This Tv , Me-Tv .
KEMV , PBS , Arkansas Educational Tv Network.
As Always , trees and tree leaves , plants and plant leaves , have a Negative Effect on Broadcast Tv Reception and so do buildings and other obstructions including your own roof and building.
Absorbing and Blocking Tv Reception in the dorections of reception.
The Best Practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
Last edited by teleview; 13-Jan-2014 at 8:45 AM. Reason: Clarify information and typos.
Old 13-Jan-2014, 4:46 AM   #5
The Y10713 is a 'cut-for-band' antenna. It's a specialty antenna intended for reception of High-VHF (real channels 7 through 13) only. In that role, it's the best performing product available until you step up to an industrial / commercial option. I paid less than $20 for mine recently, and am quite confident that this is the best option available when going after medium and weak strength H-VHF signals.
The DB8e is also a cut-to-band antenna, but designed for UHF, real CH-14 through CH-51. It can be adjusted for narrow forward beam or wide forward beam. The combination of the DB8e and Y10713 offer you the ability to fine tune aim more than a single antenna with multi-band coverage.
I own a TVPRAMP1R and use it in an application that has considerably stronger signals than shown in your report. I have had no overloading problems, a common problem with high gain amplifiers. It's also on of the few amplifiers that has separate inputs for a UHF and VHF antenna. http://forum.tvfool.com/showthread.php?t=13530
Old 15-Jan-2014, 1:03 AM   #6
Charlie84
thanks to both of you for your recommendations
will let you how it works out
Old 17-Jan-2014, 7:00 PM   #7
Charlie84
Last thoughts
About to place the order. Haven't really decided which way to go
But are both your suggestions considered the " big guns".
By that, are there any other antenna's that would be the next level for a few dollars more
I am not sure return of antennas would be an easy job, considering shipping , re ordering and etc.
A few dollars more to get it right the 1st time
Thanks
Old 17-Jan-2014, 8:04 PM   #8
All the recommended antennas are the big guns for your reception situation.
