Old 13-Nov-2010, 8:23 PM   #1
Stryker
CBS Channel 10
I live in Gainesville, MO and can not seem to get the CBS channel out of Springfield - any suggestions?
Channel Master CM3671 Antenna Direction: 325 Degrees
Radio Shack 10 dB Amp
I live on top of a hill and the antenna is about 30 to 35 feet up.
http://www.tvfool.com/?option=com_wr...81a3583e7185a6
Channels Recieving Now: 33, and 3.
Stryker is offline   Reply With Quote
Old 13-Nov-2010, 9:19 PM   #2
Tv Reception
If you have read some of the other posts then you know you need to do this http://forum.tvfool.com/showthread.php?t=4
Old 14-Nov-2010, 1:16 AM   #3
Thanks for the report...
Can you give us a description of your existing antenna, how old, model #?
What direction is it pointing or facing?
What real channel numbers are you receiving now?
Is there an amplifier - if so, model#, where, at the antenna or at the set...
How many sets are fed by the antenna system?
If you were starting from scratch, there would be several good options of either a single combination VHF/UHF antenna or two separate antennas combined at a preamplifier.
Old 14-Nov-2010, 2:09 AM   #4
Tv Reception
If you will like to receive these channels , KSPR 19 ABC , K07XL 7 RTV - This Tv - My Family - Tuff Tv , KOLR 10 CBS , KYTV 44 NBC , KSFX 28 FOX , KOZK 23 PBS , KWBM 31 MY Network , KEMV 13 PBS . I suggest Winegard HD7695P , Winegard AP8275 , Channel Master CM9521A , or http://forum.tvfool.com/showthread.php?t=460 . Mount the antenna on the roof in such a manner that the roof is not blocking the reception of the antenna.
Old 14-Nov-2010, 2:12 AM   #5
Tv Reception
Read and understand this http://forum.tvfool.com/showthread.php?t=695
