Old 13-Jul-2012, 9:16 PM   #1
kytter
3 Toledo stations MIA
We are testing a basic bunny-ears antenna and amplified indoor antenna from RadioShack to try to access our local stations, but 3 channels don't come in--PBS, Fox and NBC. We’re in Sylvania, Ohio, and all the searches we've done online show that we should be receiving them OK via UHF, as they're less than 17 miles away. We get the ABC and CBS affiliates just fine. We've tried it on the 2nd floor of our house, on the first floor on different sides of the house and in the backyard toward the east, where the towers are. Any ideas are appreciated!
kytter is offline   Reply With Quote
Old 13-Jul-2012, 9:24 PM   #2
Please read through the Guidelines when asking for help. Then post a link to your TV Fool report. We'll be able to be much more helpful with that information at hand.
Old 13-Jul-2012, 9:31 PM   #3
kytter
Signal Analysis Results
Sorry! Here is the link to our signal analysis results: http://www.tvfool.com/?option=com_wr...9900efef2da881
Channels we are most interested in are PBS, NBC, ABC, CBS and FOX. I think I answered the other questions above. I did email the FOX engineering dept, and just got this reply, "The amplifier is probably being overloaded. With only a few model exceptions, indoor amplified antennas do not work well. Might try a new channel scan, move the antenna a couple of feet and then scan again. An outdoor, non-amplified antenna works best." (We did try moving it all over the place, but maybe we need the outdoor one?)
Old 14-Jul-2012, 12:18 AM   #4
For all of the Tv channels you have requested and more.
Install a Winegard HD7000R antenna above the roof aimed at about 65 degree magnetic compass.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
---> How many Tv's are will be connected?? <---
Old 14-Jul-2012, 12:27 AM   #5
The Tv/s Must scan for the Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 14-Jul-2012, 3:24 AM   #6
Your location has receivable Tv stations/channels in ALL 3 Tv bands.
All 3 Tv bands are.
UHF band channels 14 thru 51.
Here are some examples.
WLMB-DT REAL channel 5 , Virtual channel (40.1) Independent Tv Station.
WTOL-DT REAL channel 11 , Virtual channel (11.1) CBS.
WNWO-TV REAL channel 49 , Virtual channel (24.1) NBC.
The HD7000R receives All 3 Tv bands.
------> How many Tv's are/will be connected?? <------
Old 14-Jul-2012, 6:28 PM   #7
kytter
Fixed!
We were scanning for cable stations instead of antenna. Duh! Tried it this morning for "antenna" and we get everything now. Thank you!
antennas, toledo
