Old 12-Jul-2012, 9:43 PM   #1
tjh011
Antenna Recommendation
I am new to OTA antennas and would like some opinions on whether I am likely to be able get signal from an antenna in the attic and if so, which one would you recommend??
Here is my location.
http://www.tvfool.com/?option=com_wr...9900eefa2ab62f
I would be looking for an antenna to use with: DIRECTV AM21N Off-Air Dual Tuner (AM21)
tjh011 is offline   Reply With Quote
Old 12-Jul-2012, 10:24 PM   #2
If you have a wood framed roof with composition shingles and no metal, (sheet or foil) that would block the antenna's 'view', then an attic mounted antenna could work. Still, when the roof is wet and especially if loaded with snow, expect more signal loss.
I would try this with an Antennacraft HBU-44 or HBU-55. If you get unreliable reception in the attic, the Antennacraft models are easy to re-fold, making it possible to move them outside without damage.
Old 12-Jul-2012, 10:30 PM   #3
tjh011
Thanks.
House is wood framed with a tile roof. I Live in the desert so very little rain and no snow to deal with.
Old 12-Jul-2012, 10:45 PM   #4
For reception with the least amount of situations , I recommend go straight to above the roof.
Install a Winegard HD7696P antenna Above the roof aimed at about 190 degree magnetic compass.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
-->How many Tv locations are/will be connected?? <--
The Tv's or separate tuners Must scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Do Not scan for cable tv channels or satellite tv channels.
Old 12-Jul-2012, 11:04 PM   #5
The tile roof argues against attic mounting. I concur with Electrons suggestion of the Winegard HD7696P.
