Old 9-Jul-2012, 7:51 PM   #1
medic7603
Installed new antenna but can't get 2 channels still.
I am in a bind. I had the Mohu indoor antenna and got some of the channels, but if I wanted ABC I had to move it to a different spot and then back to get NBC/FOX. CBS is out of the question with it as well as PBS. I'd really like to be able to get CBS/ABC. Both are showing as VHF Red on antennaweb. I have the Winegard MS 2000 mounted on the top of the mount of a Dish that I took off the mount that was on my roof prior to moving in. It's 10, maybe 15 feet up in the air on the roof. Now I can get PBS super clear as well as FOX/NBC(Just like before), but still can't get CBS or ABC. Any thoughts?
medic7603 is offline   Reply With Quote
Old 9-Jul-2012, 9:22 PM   #2
Do as the other question askers do and Do This -> http://forum.tvfool.com/showthread.php?t=4.
Use the Exact address to make the tvfool radar plot report.
Make the antenna height 20 feet.
Are there any Big trees close to the house and what directions that would be in the way of reception with a antenna on the roof.
Old 11-Jul-2012, 4:38 AM   #3
medic7603
Here's the TV Fool report.
http://www.tvfool.com/?option=com_wr...9900f06c3b0238
I right now have it about I'd say 12, maybe 15 feet in the air, it's on the lower end of the roof on an old Dish mount.
I plan to have 2 total tv's hooked up to it eventually.
I have a splitter outside from a Comcast install and was hoping to use that to split it outside as there's already a hole for the upstairs tv and the downstairs one existing and I'd rather not drill more holes in my house if I don't have to. However, I've found when hooking it up I get the channels I want with the exception of WWMT and WZZM but only if the antenna is sent directly to the upstairs TV(don't have a digital ready one downstairs yet.) and not through the splitter. If I put the signal through the splitter it shows no signal found.
The antenna is a Winegard MS 2000.
Hopefully that's enough information, if not let me know. Thanks again!
Old 11-Jul-2012, 4:47 AM   #4
medic7603
Oops. No big trees close to the house, not even on the same side of the street. From what I can find online the two stations I need to pick up are 153 degrees and 341 degrees from me at 20 and 30 miles respectively.
Old 11-Jul-2012, 7:21 PM   #5
MS2000 antenna is mounted horizontal like a flying saucer in level flight.
Do not install/mount the MS2000 tipped at odd angles.
The MS2000 is to be installed above the roof in such a manner that roof and etc. is not blocking reception in any direction.
The MS2000 says it is omni directional.
The MS2000 is not 100% omni directional , turning the antenna to find a sweet spot will often improve reception.
Here are places to by antenna mounts and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.amazon.com.
Some splitters pass electric power through the splitter and some do not.
The power supply/power injector can be connected on the other side of the splitter so the power supply/power injector is feeding power through coax to the amplifier that is in the saucer unit with out going through the splitter.
Or can install a power passing splitter.
The splitter will be labeled power passing. Most common power passing splitters pass power through one leg of the splitter , through one output and one input.
Here are some High Quality power passing splitters that are beyond the common power passing splitter , and Yes a common one leg power passing splitter is Ok to use.
http://www.hollandelectronics.com , also available at , http://www.solidsignal.com.
HFS-2D , 2 way splitter.
HFS-3D , 3 way splitter.
HFS-4D , 4 way splitter.
Old 11-Jul-2012, 7:32 PM   #6
If after making the reception improvement changes , the reception still is not acceptable.
Then try a ANT751 mounted up high and clear of obstructions.
Aimed at about 327 degree magnetic compass , here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
HOW MANY Tv's are/will be connected??
Old 11-Jul-2012, 7:41 PM   #7
medic7603
Thanks for all that it helps. I attached it to the second cord going downstairs and connected it to a new vizio tv I just picked up. It receives both the channels I couldn't grab with the other one(a Philips), but the one channel is choppy and I imagine a greater height would be good. I'll try that next. I'll also try the power passing splitter on the outside and the injector inside that way I can keep the injector inside since I found out its not approved for outdoor use.
Does that sound like a good idea. Cable from antenna to power passing splitter to the two cables indoor to the injector(up or downstairs cable? Or both?) and then to tv? Thanks again for helping this newb.
Old 11-Jul-2012, 8:15 PM   #8
It is best to Not chain splitters one after the other.
Do Not have a splitter connected to another splitter connected to another splitter.
Each time a split takes place the signal is -> Reduced.
So at the end of the chain of splitters there will be very little signal to receive.
The Correct Way is to use a splitter that is for the number of Tv's connected.
For one Tv connected use No splitter.
A 2 way splitter for 2 Tv's connected.
A 3 way splitter for 3 Tv's connected.
A 4 way splitter for 4 Tv's connected.
Old 11-Jul-2012, 8:49 PM   #9
medic7603
Right now one. Ultimately still just two.
Assuming the power injector counts as a splitter as well?
Old 11-Jul-2012, 9:09 PM   #10
The power injector does not count as a splitter. It does not divide the signal the way a splitter does. The typical power injector has less than 1 dB of loss. The typical 2-way splitter has 3.5 to 4 dB loss.
Old 11-Jul-2012, 9:29 PM   #11
medic7603
Ok. Good to know thanks. So does an outdoor power passing splitter to cords foun inside work? I have one power injector on one tv now and would that be sufficient with said splitter or do I need a second?
Old 11-Jul-2012, 10:38 PM   #12
This diagram may fit your situation: http://www.antennasdirect.com/cmss_f...itter_Opt2.pdf
If you need a power passing splitter but don't yet have one, here's a source: http://www.antennasdirect.com/store/splitters.html
Old 12-Jul-2012, 2:19 AM   #13
medic7603
Thanks for that diagram, it really helps. The only other question I guess I have is, is it imperative that I have a 2 way splitter with only one power pass port, or would one with two power pass ports work as well? I just want to get this done and there's some local stores that have splitters with power pass to all ports. Would that work?
Old 12-Jul-2012, 2:28 AM   #14
Avoid passing power to cable runs that don't need it. In some cases the attached tuner will load down the power supply or even short circuit it.
Take a careful look at this diagram: http://www.antennasdirect.com/cmss_f...itter_Opt1.pdf
If you have power available at the splitter location or any other point between the splitter and the antenna, this option can be implemented with a splitter that has no power pass feature, or power pass on one or more ports.
Old 12-Jul-2012, 2:30 AM   #15
medic7603
Ok, that's what I figured from looking at the diagram, but I wanted to double check. Thanks for the help, it helps a lot.
Old 12-Jul-2012, 2:39 AM   #16
There are DC-blocks available. It's an option that would convert 'power-pass' on all ports to 'power-pass' on selected ports.
http://www.summitsource.com/aska-vbc...c-p-11828.html
However, I would not install this in a wet location. It would also cost about the same by the time you had it shipped.
Old 12-Jul-2012, 2:49 AM   #17
medic7603
So. I could put a 2 way splitter with a single power pass outside though?
Old 12-Jul-2012, 3:24 AM   #18
Yes, that's true. Just be sure to use weather proof connectors or mount the splitter in a weather proof housing.
Old 12-Jul-2012, 6:13 PM   #19
medic7603
Ok, update. Happened to find a 2 way splitter with power pass through on both ports. Hooked it up and went from getting full channels downstairs and nothing upstairs to full downstairs and a few(not nearly enough) upstairs. That being said the power injector is downstairs and not upstairs, does that make a difference? Would it work better or worse to have the 2 way splitter with single power pass through? I'm just wondering if it's not injecting the power back upstairs or something. I'm at a loss here now and want to get this done as soon and frankly as economically as possible.
Old 12-Jul-2012, 6:26 PM   #20
medic7603
If I need to get a new splitter I was thinking maybe this one?
http://www.amazon.com/DIRECTV-SPLIT2...ter+power+pass
Yes/No?
