Old 29-Jun-2012, 9:24 PM   #1
superslow
Help me cut cable in Phoenix
Hi all. I would like to cut my cable. I am looking for advice on antenna and setup for me in Phoenix. I would like to put it in my attic. I have read about problems with stucco and hot attics. Would a bigger antenna help to counter that? Thanks for any advice.
http://www.tvfool.com/?option=com_wr...13496f8498c7be
superslow is offline   Reply With Quote
Old 29-Jun-2012, 9:29 PM   #2
superslow
Also, I only have one Tv and a computer with a tv card that is used to watch too.
Old 29-Jun-2012, 9:34 PM   #3
Concrete and tile products can reflect and attenuate RF. Stucco usually has wire mesh embedded for structural support. The wire mesh makes a formidable barrier to RF.
If there's no metal or foil in the roof covering or structure, I would recommend an Antennacraft HBU33 in the attic. You have enough signal per your report, I doubt the attenuation caused by the typical composition roof would cause trouble. Point it south to begin with, fine tune the aim from there. If the attic turns out to be a poor location, the Antennacraft products are fairly easy to re-fold, allowing you to move it outside without damage.
The heat wont cause trouble for an antenna, but may be a problem for a preamplifier... but you don't need a preamplifier. A common passive 2-way splitter will be fine for sharing the signal between the TV and computer.
Last edited by GroundUrMast; 29-Jun-2012 at 10:35 PM. Reason: Added links to equipment sources
