Old 23-Jun-2012, 7:00 PM   #1
lmemax
Question Reception in a Calif. Prison??
Good Evening … I realize not everyone will care whether or not a “prisoner/criminal” has access to his TV or not … but the person is someone whose very large family had “made me a part of theirs” when I was in college in California years ago (with no family of my own there) … and he will always be “dear to me” .. he made a few mistakes a long time ago, when he was 19-20 yrs old (and had no money & a terribly-over-worked court-appointed attorney) … I do have some “sympathy” for him sitting bored to death in a cell, day-in-and-day-out … So if anyone else can find the sympathy and mercy in their hearts, too, please read on for the details of his problem. (a link to the TV Signal Analysis Report is at the end, as well as what I found on the LPTV Station Search Tool results)
He has a very small RCA “digital” TV, that normally connects via a cable into a “cable outlet” in the wall (and no, they don’t get premium “cable channels” like HBO or Showtime – just “basic”/local TV stations like NBC, Fox, CBS, etc.). Now, I know he’s only had this “digital-ready” TV for a year or two, and I don’t know if this “cable outlet in the wall” is how he used to always connect his “analog” TV and get reception, too, or what. In other words, I don’t know if having “cable wall outlets” is something relatively new in the prison – like, something they’ve had to start using because of “digital-ready” TVs (and how that’s the only kind available for the inmates to buy, now) – or if they’ve always used them (because of the very poor, or complete lack of, reception in that geographic location). The topic of how his TV “connects” has never come up before! But he recently got moved to another building in that prison, and he said there’s no “cable wall outlet” in the cell, to plug his TV into. He uses the word “our” and the plural form of “outlet” and “cable” (as in “there’s no cable outletS to plug OUR TV cableS in to, over here”), and I’m not sure if that means “that section” of the building he is in doesn’t have them, or the entire building doesn’t.
This is what he wrote to me: “There are no cable outlets to plug our TV cables into, over here .. So we have to rip our cable to the TV and make a circle, then hang it in the cell to find reception. I found 2 channels, only … I’ve been moving the cable all around the cell trying to get better reception and more channels, but nothing yet. The cable is about 5 feet long .. I’m going to try 2 cables together as soon as I buy another cable from store.” So he asked me to do a little Internet research to see if I could find any “tips or tricks” for getting reception (or better reception) on a digital TV, when you only have a “cable” to use as “makeshift antenna.”
So I did a TV Signal Analysis Report on your site (geez, what a great site, too! So much info – I learned a lot!). I had also tried to find out what 2 stations he might be getting in – I looked his zip code up on the Low Power TV Station locator http://fjallfoss.fcc.gov/eb/zipsrch/ (because I had also discovered and read about LPTV) as well as a few surrounding zip codes, and they showed K36FO (channel 36) coming from Calexico, CA, and K56GC (channel 56) coming from El Centro/Holtville, CA. But in looking at the TV Signal Analysis Report on your site, I can’t seem to locate those stations .. So, can anyone read this report and tell me what you think ? Is it going to be “possible” for him to get any other channels in, without a “good, normal” antenna (like “rabbit ears” or “loop/bow tie” types)?? If yes, what can he do? (for instance, will tin foil help?) When I look at the report, even though I can’t “read” it or understand what each table is, from the first colored circle graph, it doesn’t look like he is within reception of anything. And that was my first thought when I read his questions – that since he’s basically out in the desert, in the middle of nowhere, with at least one “forest” that appears to be on one side of the perimeter, and probably mountainous terrain on others, that are between him and any towns/cities that might have towers, that chances were remote that he was going to pick up any stations without being attached to some VERY STRONG antenna OUTSIDE, or a cable …. So, here’s the report:
http://www.tvfool.com/?option=com_wr...1349333b9d89a7
And thanks for anyone and everyone who can help!
lmemax is offline   Reply With Quote
Old 23-Jun-2012, 7:25 PM   #2
signals unlimited
The stations located at 89 and 297 degrees magnetic could be received from that location.
The concrete and steel may make it a litle difficult. If there are windows or if he is located on the East or Northwest side of the building it will be easier to make this work.
Can you take in a rabbit ear antenna? If not I will tell you how to build something from a metal coat hanger or foil on cardboard.
Old 23-Jun-2012, 8:01 PM   #3
lmemax
Thank you! I am walking out the door to a graduation party for my niece ... I will be back later tonight and will check back here right away ... I don't know what he has access to in order to "make" an antenna - but please tell me how, and I will pass it along to him - he can then try whatever he can. At this point, I am taking any and all suggestions, and will pass them along to him, so that he can try to figure something out.
I really appreciate your help ... as I don't know anything about this "signal" stuff!!
I will be back later to look for your instructions on this!! Again, Thank you!!
Old 23-Jun-2012, 9:58 PM   #4
signals unlimited
Take two strips of foil 5" long. mount them on cardboard end to end with a 1" gap between them. Strip the coax to expose two wires (The center conductor and the sheild). Attach these wires to the foil at the gap. Mount the antenna in a horizontal position and aim to one of the directions mentioned. Scan the DTV for antenna channels. If he can not get the foil any metalic material (wire ect.) will work.
It doesn't matter how wide the material is. The important thing is the length.
Good luck!
Old 24-Jun-2012, 4:03 AM   #5
lmemax
Thumbs up Great Idea!! Thank you!!
Dear Signals Unlimited: Thank you so much!! I am going to cut and paste your instructions into my letter to him (which I will hopefully be able to finish in a few days) ... I live in Michigan, so it will take 3 days for my letter to get there, and hopefully the prison mailroom will pass it along quickly.
I don't know if they ever get anything with tin foil that he can use ... but they are pretty "resourceful" when it comes to "finding suitable replacements/substitues" for whatever they lack or don't have access to behind prison walls! (I have been "wowwed" and "in awe" so many times, by the ingenious and "creative" ways they come up with to "adapt" to their circumstances and stark environment ... it's truly amazing)
So again, thank you for taking the time to help and explain how to make the antenna .... It's truly appreciated.
