Old 28-Oct-2010, 6:06 PM   #1
gmmt99
TV Antenna Purchase Recommendations - Illinois
This website was referenced in an article in the Chicago Tribune this past Sunday. I don't have any idea about what type of antenna I need. This is a great website. Thank you. I did complete the TV Signal Analysis Report, and it is attached below:
http://www.tvfool.com/?option=com_wr...a5435e7d976744
Currently, we have no TV service....dish or cable. The home is located in Galena, Illinois (northwest corner of Illinois....more hilly and a fair amount of trees). I would like to get an antenna (probably will need to be external) that would allow me access to some local stations and whatever else I can get. Once I purchase the antenna that you recommend, I will find someone to install.
Your recommendations for an antenna would be greatly appreciated as I don't know what to buy. Thank you in advance for your assistance.
Greg
gmmt99 is offline   Reply With Quote
Old 28-Oct-2010, 7:21 PM   #2
Tv Reception
How many floors above ground level is the house? The higher the antenna the better. Please rerun the report with antenna as high as you think you can get it. Also how many tv's will be connected?
Old 28-Oct-2010, 7:23 PM   #3
At best, expect to receive four stations, if you are willing to install a large UHF/VHF combination such as the CM3761B http://salestores.com/chma36ulcrse.html
A rotor will be needed.
A high quality preamplifier will be needed. For example, http://www.antennasdirect.com/store/...e_amp_kit.html
The higher the antenna can be mounted the better.
Here a some threads re. installers: http://forum.tvfool.com/forumdisplay.php?f=8
A well qualified installer will have local knowledge and be equipped to put a test antenna in the air so that you can know what to expect from the completed install.
Last edited by GroundUrMast; 28-Oct-2010 at 7:36 PM. Reason: considering updated report
Old 28-Oct-2010, 7:32 PM   #4
gmmt99
Response to Questions
Hi:
Here is a rerun of the report as requested:
http://www.tvfool.com/?option=com_wr...a54349700aedf1
There will be a maximum of three TV's.
Hope this helps. Thank you all for your help.
Greg
Old 28-Oct-2010, 8:21 PM   #5
Tv Reception
For some one else to install the antenna and do the wiring , type in , structured wiring galena il - or - structured wiring dubuque il . in the google search box. or contact zip installation.
Old 28-Oct-2010, 9:48 PM   #6
It looks like ABC, FOX, and NBC are too weak to receive reliably unless extreme antennas are considered. Also, the stations arrive from multiple directions.
A HD7698P aimed at 227 and a Antennacraft Y5-2-6 aimed 187° plus an AP8700 preamp and an HLSJ to add the two antennas prior to the preamp will get CBS, CW, and PBS.
