Old 15-Jun-2012, 6:25 AM   #1
Blackbeen
Eagle Aspen ROTR100 cable question
I've never installed a rotor before. When I inquired information on the cost of cable from the receptionist of the installer I'm using she gave me 2 different prices by foot for rotor & coax cable, as far as I can tell: http://www.antennasdirect.com/cmss_f...%20-%20PBI.pdf the
Eagle Aspen ROTR100 just uses standard coax cable to power the unit (with a separate power connection). Is this atypical for rotors? I know they generally install Channel Master rotors & I don't know if those use a different cable type.
Blackbeen is offline   Reply With Quote
Old 15-Jun-2012, 10:25 AM   #2
Traditionally, TV antenna rotators have used 3 or 4 conductor, non-shielded cable between the control unit and the rotator. The Eagle Aspen design is unique in that it uses RG-6 coax instead.
So to answer your question,
Yes, but RG-6 is cheap and easy to obtain now days so 'atypical' is not a bad thing.
Old 15-Jun-2012, 1:36 PM   #3
Blackbeen
So to answer your question, Yes, but RG-6 is cheap and easy to obtain now days so 'atypical' is not a bad thing.
Yes, she quoted me 50 Vs. 32 cent a foot so this is good.
cable, coax, rotors
