Old 24-Oct-2010, 1:21 PM   #1
meiz
Lines pointing to each transmitter
Hi,
The check box "Show lines pointing to each transmitter" is not available and I can't uncheck "overlays off". What's wrong?
meiz is offline   Reply With Quote
Old 24-Oct-2010, 8:12 PM   #2
The option for drawing lines to the transmitters is not available in browsers like Safari and Chrome (derived from the WebKit project). There is a known memory allocation bug in those programs that can sometimes cause the browser to crash. This feature will be re-enabled if/when the bug in these browsers gets fixed. For now, you'll need to try a different browser (like Firefox, Opera, etc.) to access the "show lines" option.
The "overlays off" option is a radio button, and not a check box. You can choose to display any of the station coverage overlays in the list below the map (radio buttons only allow you to select one item at a time). Selecting any station will un-select all other options (including "overlays off"). If you do not want to display any coverage overlays, the "overlays off" selection turns off all other selections.
Old 25-Oct-2010, 2:30 AM   #3
Btw, I misspoke earlier about being able to see the lines via browsing on an iPad.
Old 25-Oct-2010, 9:47 PM   #4
meiz
Thanks for the info. I am using Google Chrome so I added the I.E. plugin for Chrome and the lines now show up. Thanks
