Old 29-May-2012, 8:49 PM   #1
godboss
Help Me Slect a better Antenna and set up.
Please Advise me to pick up a Better Antenna and set up instructions for the following location:
http://www.tvfool.com/?option=com_wr...073b8bee23fbca
This will Go above the roof of a 2 story Brick home with shingle roof.
Thank you.
godboss is offline   Reply With Quote
Old 29-May-2012, 9:21 PM   #2
ALL Questions and Answers and Information - Broadcast Tv Reception and More
Old 29-May-2012, 9:56 PM   #3
godboss
At This Time Only One Tv!
Old 29-May-2012, 10:38 PM   #4
For reception of the Canada Tv stations/channels and the American Tv stations/channels.
Install a Winegard HD7696P antenna with a Winegard AP8700 preamp above the roof aimed at about 127 degree magnetic compass.
Here are some places to buy antennas and ect. , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.amazon.ca , http://www.canadapost.ca/shopper , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com.
Old 29-May-2012, 10:44 PM   #5
The Tv Must Scan for the Broadcast Television Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Old 30-May-2012, 3:46 PM   #6
godboss
Thanks Electron for quick response. I understand this suggested set is the best. Do you have any altrnate suggestions, may be little less than the best but good enough.
Old 30-May-2012, 6:00 PM   #7
For this reception situation this is the least that can be recommended for reliable reception.
I was going to recommend a 2 antenna installation , one for Canada and one for American.
You could do without the AP8700 preamp at this time. WPXJ-DT ION is Very Weak signal strength.
The AP8700 preamp is mainly for reliable reception of WPXJ-DT ION. If WPXJ-DT is not received reliably with out the preamp , you could add the preamp later.
Here are some examples of antenna mounts , The Ronard mounts are High Dollar , you can search on the internet and find the same type and kind of antenna mounts for less money. http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Or you can make up your own antenna mount. Make sure the mount is strong and secure so the antenna will not fall and break. Reason: the antenna cost is a few more dollars , then a few.
I Strongly Recommend use the HD7696P antenna , the HD7696P antenna is the best antenna for your reception situation.
Do Not get a , HD7694P , HD7695P , HD7697P , HD7698P. And I do not recommend any other type or kind of antenna.
