Old 13-May-2012, 10:09 PM   #1
furbymac
channel 45 (59.1) issues
I just recently purchased and cm2018 and have it mounted right around 20 ish feet. i am having no issues with any of my other channels but wxin my fox affiliate here in central Indiana keeps cutting in and out. the signal strength is right around 97% and it jumps all the way down to 0% and then back up and kinda fluctuates between 82% and 87% then back up to 97%. haven't had any issues with this channel untill today. i have it pointed to approximately 213.
Any ideas of what i should be looking for or what could be causing interference.
http://www.tvfool.com/?option=com_wr...de657deea385fb
furbymac is offline   Reply With Quote
Old 14-May-2012, 9:58 AM   #2
signals unlimited
The interferrence that you described in narrow band. This eliminate many sources such as electrical interferrence. This leaves the possibility of any device in your home such as a modem, or any wirless device being used. Anything new? Next and more difficult it could be something in your neighborhood. GPS, remote monitoring, ect.
Good luck!
Old 14-May-2012, 12:00 PM   #3
furbymac
I think I figured it out. I was aimed right at a tree so I turned it to about 225 and it seems to have helped enough that the signal isn't dropping below 87 now. But it still fluctuates between 97 and 87% alot.....I can't wait till I cut that dumb tree down.
Old 14-May-2012, 5:50 PM   #4
Removal of the tree will probably provide a permanent solution.
You might try a different mounting location for the antenna first as that may preserve the benefits of the tree.
Old 14-May-2012, 6:17 PM   #5
furbymac
I have had plans to remove the tree before the antenna came around. It drips sap on the cars anyways.
