Old 22-Apr-2012, 3:17 PM   #1
samve33
Trying to figure out my best options
I've been taking a crash course on antennas for the last couple of days and I THINK I've got a decent understanding now.
About 3 months ago I kicked cable to the curb and put up an antenna and use services such as Netflix. Overall I've been satisfied with this set-up.
About a month ago channel 2 WSB out of Atlanta started giving alot of problems. Other channels gave problems too. After several days of checking the antenna it dawned on me that the trouble started about the time the leaves popped out on the trees. So after clearing some trees I was able to make a good deal of improvement, but channel 2 still gave problems. I finally moved the antenna around and was able to get 2 very well with an improvement in channel 11WXIA out of Atlanta also. The problem is I lost other channels.
I'm using an Antennacraft HBU55 on a 20 foot pole and rotor and a hunk of junk radio shack preamp. I'm looking at a cm-7777 now.
If i tried to raise the antenna any futher I lose channel 2. I tried 5 more feet.
2 is a must have channel with channel 3 WRCB out of Chattanooga being second.
I would like to get those lost channels back and hopefully some other channels that I believe I should be able to. Get such as channel 5 WAGA out of Atlanta.
I see several options. First, a better preamp. The others being different antenna arangements.I'm thinking about a second HBU55 on the same mast located back in the old location. Or how about another HBU55 mounted fixed on a 20 foot mast in the present location and move the present antenna with rotor back to the old location and raise it 5 to 10 feet. Other channels did come in better 5 feet up. Got any other sujestions? I appreciate your help.
http://www.tvfool.com/?option=com_wr...7fcf0ca344ecd0
Last edited by GroundUrMast; 22-Apr-2012 at 4:41 PM. Reason: Repaired BBCode for TVFR
samve33 is offline   Reply With Quote
Old 22-Apr-2012, 5:43 PM   #2
During and after the switch from Analog to Digital Tv transmission in 2009 many Tv stations are now transmitting on a different Tv channel.
There are now REAL Tv channels and Virtual Tv channels.
WSB and WRCB are examples and not the only examples there Many more Tv stations that are transmitting a different channel then Virtual channel.
WSB was transmitting on Analog VHF low band channel 2 and is Now transmitting on UHF channel 14.
WRCB was transmitting on VHF low band channel 3 and is now transmitting on VHF high band channel 13.
Many Tv stations kept there old Legacy analog channel number (now the virtual number).
The main reason is , Channel Branding.
WSB is known as the number 2 so the Tv station keeps the number 2 even though the station is actual transmitting on UHF channel 14.
Tv Antennas are selected by the REAL channel that is being transmitted and received , not the Virtual channel number. The tv fool radar report shows both the REAL channels and Virtual channels.
Old 22-Apr-2012, 6:03 PM   #3
Reliable reception of the Atlanta stations will require even more antenna than the HBU-55.
Looking at WSB, real channel 39, the predicted signal in the air is 11.0 dB below the strength needed for reception with a 'standard' dipole connected directly to the tuner. The HBU-55 has a published gain of about 9 dBd in the UHF band, so you are theoretically 2 dB short. An Antennas Direct 91XG has published gain of 15.57 dBi (13.42 dBd) at 622 MHz which is within CH 39. On paper, this begins to put you in positive territory. {11.0 dB NM} + {13.4 dBd antenna gain} = 2.4 dB net Noise Margin at the antenna output.
I would want to give you a solution that provides at least 10 dB net NM at the antenna output, 15 dB net NM is not over-kill IMO. That means that you may have to consider a tall tower to put the antenna at an elevation with more available signal.
Then, to receive high-VHF signals, (real CH-7 through CH-13), you'd need a high-VHF antenna such as the Antennacraft Y10713 or Winegard YA1713.
The CM7777 is a good fringe area preamp. The Antennas Direct PA-18 is in the same class and has better noise performance.
Bottom line, You can improve your situation, but you need to take what some may consider 'extreme measures'. You are up against curvature of the earth, hills and vegetation all of which block your view of the transmitters in Atlanta.
Old 22-Apr-2012, 6:05 PM   #4
That said , the real channels at your location are located in the channel ranges of VHF high band 7 thru 13 and UHF 14 thru 69.
Most of the REAL digital Tv stations/channels are Very Weak at your location.
Install a Winegard HD7698P antenna with a Winegard AP8275 preamp aimed at about 355 degree magnetic compass.
Mount the HD7698P antenna above the roof.
Here are some Strong and Sturdy antenna mounts. http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com.
The HD7698P is a Long Rang Maximum Reach All In One Antenna , and the AP8275 preamp has gain and noise figures that match the CM7777 and PA-19.
Old 22-Apr-2012, 6:13 PM   #5
I agree with @Electron, the Chattanooga stations should be easier to receive reliably.
Have you tried aiming your HBU-55 in that direction?
Old 22-Apr-2012, 6:52 PM   #6
What direction is the HBU55 aimed , north or south??
Aim the HBU55 antenna at about 335 degree magnetic compass (north).
I am doing my best to get you the tv stations with out installing 2 antennas or a antenna rotor.
WSB-Tv 14 ABC that shows as virtual channel 2 on the tv screen is located at 217 degree and WPXA-DT 51 ION that shows as virtual channel 14 on the tv screen is located at 98 degree magnetic compass.
To improve reception of ABC and ION , remove the UHF reflectors that are shaped like this >.
The vee shaped reflectors. Or adjust the reflectors so the reflectors are straight up and down like is | .
This will get the reflectors out of the way so more of the signal of the ABC and ION tv stations can be received at the side and back/angle to the antenna.
To prove out the reception. Connect a known to be good matching transformer (balun) to the HBU55 and connect a known to be good coax to the balun and run the coax through a open door or window direct to one tv.
No splitters and preferably no coax couplers. Remove ALL of the amplifier , the out side part the inside part and any or all other parts of the amplifier and power supply of the amplifier.
With the HBU55 a known to be good balun and a know to be good coax direct to the tv. What is the reception like now??
Old 22-Apr-2012, 7:32 PM   #7
samve33
The antenna is on a rotor and Chattanoga DOES come in much better than Atlanta.
I'm happy with the signal from WSB right now. It's 70% to 75% . I would be happy to mount the HBU55 fixed in it's present location for WSB and go with a different one in the old location. If I used the one you segest, could I combine the signal with the HBU55? I hate to chunk a new antenna.
I may have a deal on a 7777. Won't know until tomorrow. If that falls through then I'll go with one of the others.
All the channels I lost by moving the antenna was in the UHF band.
Thank you very much for your quick responses.
Old 22-Apr-2012, 7:39 PM   #8
Make the recommended adjustments with the HBU55 and test hook up connections. And report here with the reception. WFLI-DT 42 The CW is very weak , how is the reception of WFLI ??
The 2 antennas HBU55 and HD7698P can not be connected together on to one coax. The rotor you have can be used to 'fine tune' the reception.
Do the test adjustments to the HBU55 UHF reflector and balun and coax and one tv and retun with a report.
Old 22-Apr-2012, 8:00 PM   #9
samve33
I found the HD7698P for $61. I'm willing to give that a shot. The question now is location and height. With this antenna I wonder if I can go back to the old location where the other channels are stronger AND raise it 5 to 10 feet without losing WSB again. Let me know if you think I should jump on the HD7698p and I'll order now.
Old 22-Apr-2012, 8:22 PM   #10
samve33
How about this option? If I go with the HD7698P and use the rotor and the 7777 or similar, then I'll have a leftover antenna and preamp which is working fine where it's at for WSB. If I use the new setup to maximize my other channels and disregard WSB and WSB does not come in well I guess I could put the HBU55 back in it's present location and run the two antennas to an A/B switch. What you think?
Old 22-Apr-2012, 9:20 PM   #11
samve33
My mistake. That was a hd7695P for $61, not the hd7698. I shopped around and found it for $115 with shipping. Still in the doable range. If you think it's worth it, I'll go for it.
Old 22-Apr-2012, 9:42 PM   #12
Using the tvfool radar report Pending Applications Included of Digital Tv Stations/channels. For two antennas , one on a rotor and one in a fixed position.
I would do it this way. Mount the HD7698P antenna with the Winegard AP8275 preamp in a fixed position aimed at about 355 degree magnetic compass for the for sure reception of the Tv stations from the north/west , north , north/east.
And put the HBU55 on the rotor for the reception of WSB-TV 14 ABC and WPXA-DT 51 ION if not received by the HD7698P (I think WSB and WPXA will be received by the HD7698P). And the HBU55 can rotate to receive WTJP-TV 26 Trinity Broadcasting Network (there is also another TBN to the north that will be received by the HD7698P WELF-TV 16 TBN) . , WCIQ 7 PBS , WXIA-DT 10 NBC , WGTV-DT 8 PBS , WATC-DT 41 IND.
Here is a Remote Control A/B antenna switch Radio Shack # 15-1968 .
Old 22-Apr-2012, 9:48 PM   #13
Aiming the HBU55 inbetween REAL channels 26 , 14 , 7 , will get those 3 and aiming the HBU55 at REAL channel 8 will get REAL channels 10 and 41. This what is on 41 http://en.wikipedia.org/wiki/WATC-DT
Old 22-Apr-2012, 10:08 PM   #14
samve33
I'll get the HB7698P on order right away. Prehaps the wind will have died down by the time it gets here. Let me give you a list of the channels I have now. 2, 3, 7, 8, 9, 11, 12, 14, 17 is now weak, 18, 21, 23, 60 is now weak. I lost 46, 53, 61, 63, and 69. I think this is all the channels I've got now or had.
Old 22-Apr-2012, 11:38 PM   #15
samve33
One other thing, which antenna gets the good preamp or should I chunk the Radio Shack and get 2 good preamps?
Old 23-Apr-2012, 2:01 AM   #16
If it were me I would put the radio shack amp in the trash. However it is your choice not mine.
Old 23-Apr-2012, 2:43 AM   #17
samve33
Good enough. It looks like it'll be 2 AP 8275 amps since the bid I had going on the 7777 got to be more than I could get the 8275 for. I'll get everything ordered up and give you a shout back when all is in place. This week I hope. Any mods to the new antenna or anything else I need to do before I put it up? Thank y'all very much for all the help and I'll contact you again soon with the results.
Old 27-Apr-2012, 10:45 AM   #18
samve33
Everything is here except the antenna. It's expected to come in today and hopefully I can jump on this tomorrow. Let me ask you this. Since I'll have 2 preamps the same with 2 coaxs coming to the tv, could I combine the 2 antennas after the preamps on the inside and not use the A/B switch?
Old 27-Apr-2012, 11:58 AM   #19
signals unlimited
Combinding antennas that are aimed in different directions in the same band will always have a negetive effect on some of the channels. To get the best results from your investment and all of your hard work, use the A/B switch.
Old 27-Apr-2012, 3:50 PM   #20
The answer of combining antennas for your reception situation is one single word , NO .
Antennas can be combined in the same direction to increase gain.
Antennas can be combined such as Separate UHF and VHF antennas using UVSJ.
Separate antennas can be combined such as VHF low band and VHF high band using a LHSJ. However for your reception the one word answer is , NO .
Yes you can connect the antennas you have together with out the amplifiers to prove a point , use a splitter in reverse.
