Old 4-Oct-2010, 4:24 PM   #1
JBK
Atlanta - Channel 36 WATL-DT - error?
AntennaWeb.org shows Channel 36 is on RF 25
It also shows the compass direction from my house the same as for most of the other Atlanta stations such as chanels 5, 46, 17, and 34. These stations are all SE 113 degrees from my house in zipcode 30127, and I can pick up all these with an RCA ANT1500 with no problem.
TVFool shows it at about SE 170 degrees.
and doesn't show 57 (RF 41) at all?
JBK is offline   Reply With Quote
Old 4-Oct-2010, 5:48 PM   #2
Hmmm. Would you mind posting a link to your report?
Our database appears to be showing everything exactly as you say it should be... WATL is on channel 25, and it is located near the other Atlanta transmitters. WATC does show up as channel RF 41 / 57.1. Sorry, but I just don't see any of the issues that you mentioned.
Old 4-Oct-2010, 8:15 PM   #3
JBK
But oops, sorry, I do see that the map has the RF numbers. I misread it thinking 36 was the virt channel #.
The antennaweb.org just shows virtual channel 57 (WATC-DT) as RF 41 and doesn't list it as also having an RF 36. No wonder I'm confused!
http://www.tvfool.com/?option=com_wr...a36251ebf3103f
Thanks for the fast response!
