Old 4-Apr-2012, 1:03 AM   #1
kipper01
Question Reception help & Antennae
Looks like a attic antennae would work for this but we have a metal roof on the camp. Or would an attic antennae work?
http://www.tvfool.com/?option=com_wr...267e5a2a9050d1
What would be a recommendation on an attic/outdoor antennae to use? The plan would be to mount it on the side of camp and hook to one TV.
Is one model or brand better than another?
kipper01 is offline   Reply With Quote
Old 4-Apr-2012, 1:11 AM   #2
The default antenna height of the tvfool radar report is 10 feet. The tv transmissions are weak at your location. Lets see if the signal strength will improve with a higher antenna. Make a tvfool radar report with the antenna at 25 feet.
Old 4-Apr-2012, 1:23 AM   #3
kipper01
Here is 25 feet. It is located on top of hill in area along with some trees in the area...If needed I can provide a picture of camp and surrounding area.
http://www.tvfool.com/?option=com_wr...267e7d2bc1789c
Old 4-Apr-2012, 2:33 AM   #4
Photos of the trees would help. How tall are they generally?
Old 4-Apr-2012, 7:27 AM   #5
Pictures of the camp and camp building and trees in the direction of about 300 degrees magnetic compass , the direction of the tv transmitters would be helpful.
Old 4-Apr-2012, 2:51 PM   #6
kipper01
Here is picture of camp with woods surrounding it. Not a great picture but gives you an idea. My plan would be to mount antennae to the side of camp somehow near the peak of the camp on the right side of the photo. Which is on the north side.
Main TV transmitters are locate to the NorthWest...Approximately.
The trees are full grown and reach way above the camp.
I should also note a camp down the hill has a rather large antennae mounted outside there camp. I plan on visiting them in a couple weeks to see how they have there setup is and quality of channels, etc. They are half way down the hill and I would also guess the hill is blocking the TV transmitters from Erie, PA
Old 4-Apr-2012, 9:07 PM   #7
Install a Winegard HD7698P antenna , Up High , aimed at about 300 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/antenna/pointing/pointing.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the ronard mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com.
