Old 19-Mar-2012, 3:02 AM   #1
Poormountaineer
Antenna selection
I am looking for advice on an antenna for my parents.
http://www.tvfool.com/?option=com_wr...0b867b942d9f13
They would like to receive all the stations from the northeast (real channels 19, 13, 31, 11; 15 and 17 would be a bonus, but aren't necessary). Since none of these channels carry CBS in HD (720P or above), they would also like to get real channel 12. Is this possible to do without a rotor or without multiple antennas?
Poormountaineer is offline   Reply With Quote
Old 19-Mar-2012, 4:59 AM   #2
K29EB 29 Fox , WIRT-DT 13 ABC and Me-Tv , WRPT-DT 31 PBS , KCCW-TV 12 CBS , KAWE 9 PBS , KRII-DT 11 NBC and The CW and CBS and MyNetwork. Install a Winegard HD7698P with out a preamp aimed at about 32 degree magnetic compass (KRII) the weakest station to receive that needs to be received of the stations/channels listed. KCCW 12 will most likley be received through the back side of the antenna. KAWE 9 PBS may or may not be received on the side of the antenna. In any event a full complement of receivable networks will be received.
Old 19-Mar-2012, 6:30 AM   #3
http://en.wikipedia.org/wiki/KQDS-TV , http://www.en.wikipedia.org/wiki/WDSE , http://en.wikipedia.org/wiki/WCCO-TV , http://en.wikipedia.org/wiki/WDIO-DT , http://en.wikipedia.org/wiki/KAWE , http://en.wikipedia.org/wiki/KBJR-TV. . http://www.rabbitears.info also has information about tv stations.
Old 19-Mar-2012, 6:50 AM   #4
If KRII/KBJR is a little weak with 2 tv's connected using a 2 way splitter then install a Channel Master CM3412 distribution amplifier in place of the splitter , and if some channels are dropping out with a 3 or 4 way splitter then install a Channel Master CM 3414 distribution amplifier in place of the splitter.
