Old 8-Mar-2012, 11:57 PM   #1
doogy2004
Need Antenna Advice
I'm looking to get some advice on an antenna. I'm open to either indoor or outdoor antennas. I would also consider a multi-antenna setup, such as one antenna pointing north and a second pointing east-south-east, if it makes any difference or is needed. I would also like to have the correct equipment to run multiple TVs.
TV Signal Analysis Results - http://www.tvfool.com/?option=com_wr...0b864c432c44ec
I would like to be able to pick-up the following stations/channels:
WYLH - CW
WGAL - NBC
WHP - CBS
WHTM - ABC
WITF - PBS
WPMT - FOX
Thanks in advance for any assistance.
doogy2004 is offline   Reply With Quote
Old 9-Mar-2012, 3:52 AM   #2
A one antenna solution. Mount a Antenna Craft U8000 with a Antennas Direct CPA-19 preamp , above the roof. Aim the U8000 at about 125 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. The reflector rods of the U8000 will be removed so the U8000 can receive in two directions. Remove the reflector rods by drilling out the rivets that hold the metal clips that hold the reflector rods in place. Now the >< shaped metal reception elements will receive at the front and back of the antenna. Now the U8000 will receive the tv stations to the , north , north east , east , south east. Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennacraft.net , http://www.antennasdirect.com , http://www.amazon.com , http://www.ramelectronics.net . Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. Buy the ronard mounts from solidsignal by typing the word ronard in the solid signal search box or buy from ronard.
