Old 2-Mar-2012, 2:24 AM   #1
ChefTamara
Attic antenna installation
Hi,
I am installing an antenna in my attic at about 30' above ground level. Most of the channels that I am interested in receiving are about 40 miles away at a 30 degree heading. I have an RG6 75ohm quad shielded coax cable with a copper clad steel conductor run from my attic to my lower level to a single digital TV. The total distance is about 90 feet of cable.
I tried the Antennas Direct DB8 multidirectional antenna with a Winegard ANWI8700 preamplifier, but all I received was channel 30 with a maximum of 56% signal strength coming from Goldvein, VA, which is about 12 miles away.
I am hoping that someone on this forum can help me choose the best antenna for my purposes. I know that attic installation is not ideal, but my HOA won't allow outside installation. Here is my TVfool analysis: http://www.tvfool.com/?option=com_wr...0b8673335f174d
Please advise.
Tamara
ChefTamara is offline   Reply With Quote
Old 2-Mar-2012, 3:47 AM   #2
ChefTamara
FCC voids HOA restrictions, but...
Hi,
I noticed someone's post on the FCC position on HOA restrictions. That is great information for the future if I can't get my attic setup to work, but since I have already paid the electrician to run the cable from the attic to the lower level, I'd rather not have him come back out to roof mount.
I am only installing the antenna so that my elderly mother can access the stations in the region that I previously mentioned. Personally, I don't watch TV anyway.
Looking forward to your responses!
Tamara
Old 2-Mar-2012, 5:25 PM   #3
Is the antenna aimed at about 40 degree magnetic compass?? The >< shaped metal reception elements are directed at the transmitters. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. The best for reception is wood frame with wood or vinyl siding and standard composition singles. The following will reduce or block Tv transmissions , metal roof , metal siding , concrete walls , concrete blocks , cinder blocks , bricks from ground to roof , solar panels. Also check ALL connections , look inside of the connectors on the ends of the coax , if the foil shield / shield wires are pushed in or are touching the center wire of the coax , use the point of a knife or Small flat blade screw driver to push the foil / wires away from the center wire. If the foam that surrounds the center wire is smashed flat use the point of a knife or Small flat blade screw driver to make the foam more round around the center wire. Are there any splitters , some splitters are designed to pass power from the preamp power supply to the preamp and some do not. Put the power supply of the preamp on the same coax that the preamp is connected to , that way you know that the preamp that is mounted close to the antenna is getting power. You should receive several channels even without a preamp. A way to 'prove out' a antenna and reception is to connect a known to be good coax to the antenna and run the coax Direct to the Tv and connect direct to the Tv that has Digital Broadcast Tv Tuner. Also the Tv needs to scan for the Digital Broadcast Tv Channels , sometimes called the 'Air Channels' or 'Antenna Channels' . Do Not scan for cable tv channels.
Old 3-Mar-2012, 8:47 PM   #4
ChefTamara
Electron,
Thank you for your reply. I pointed the antenna 30-50 degrees magnetic compass and found the best reception between 35-45 degrees magnetic compass, which produced 52-56% signal strength. I did not state however that I live in a townhouse with a brick front and I am the second townhouse in. The antenna is pointed out of my roofline and potentially through a portion of my neighbor's roofline. They also have a brick front.
I will check the coax connectors since the electrician spliced the preamp in as you described. I'll also check the coax antenna against a "good" coax to ensure that it isn't a coax issue. It will take me several days to get to that, but I'll let you know how things progress.
Thanks again,
Tamara
Old 4-Mar-2012, 2:40 AM   #5
For much better reception. Install a Winegard HD7696P antenna with a Antennas Direct CPA-19 preamp above the roof. Aim the HD7696P antenna at a starting point of 40 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html . http://www.ronard.com/ychim.html , http://www.ronard.com. To buy the ronard mounts at solidsignal type the word , ronard , in the solidsignal search box or buy from ronard. Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.antennasdirect.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com. Here is the Federal Law that says Yes you can install a outside antenna above the roof in a manner that gets the best reception. Thats a nice clear shot at the transmitters. http://www.fcc.gov/mb/facts/otard.html
Old 4-Mar-2012, 3:30 AM   #6
I'm also afraid anything in the attic, regardless of size, will provide reliable reception of the DC channels. The absolute minimum antenna I recommend would be the Winegard 7694 mounted at least 5 feet above the roofline. The 7696 recommended by Electron would be an even better choice if at all possible.
The Winegard 8700 preamp is a good choice & will help with the DC channels once the antenna is outside.
