Old 24-Feb-2012, 12:51 PM   #1
LOTL
The Grand Plan needs help
Hi All,
Thought this would be a good place to start before embarking on my quest to abandon Comcast cable.
We live in a 3 story home that we hope to sell within the next 2-3 years (depending on where housing prices go).
We have the 3rd floor closed down and i was thinking of placing the antenna i get, up in which ever room provides the best reception.
I know an outdoor mount may be inevitable, so im open to that as well.
I was thinking of using the Coax that is already run to the 2 rooms for the Antenna feed back to my Homerun HDHR3-US tuner. I believe the coax is RG-59 and i suspect not of the greatest quality.
Is RG-6 preferred? Should i just run a new cable and if so any recommendations on cable. RG-6 seems to be the way to go, is shielding critical? Quad shield seems to be more a buzz word, is it necessary?
Heres my TV Fool report:
The Grand Plan report
I may have asked too my questions here, but my main one is what antenna you folks might recommend. I appreciate any input.
LOTL is offline   Reply With Quote
Old 24-Feb-2012, 7:41 PM   #2
I also run SiliconDust products in my home network. http://forum.tvfool.com/showthread.php?t=820
It looks as if your hope of mounting the antenna(s) indoors has a fairly good chance for success, the signal levels available to you are actually very good for the most part.
I would suggest using an Antennas Direct DB-4e facing SE. This antenna is reasonably compact but it out performs similar 4-bay panel antenna designs. Like other UHF only antennas, it lacks coverage of VHF channels (real channels 2 through 13). From indoors, that would only impact your ability to receive WMUR, but WCVB is an ABC affiliate that will be easy to get.
Try the existing coax. Quad Shield is not needed for OTA applications (though it will work fine).
If you want to consider reception of some of the weaker signals to the NE, Multiple HDHR's can be used to terminate multiple antennas.
Old 24-Feb-2012, 8:38 PM   #3
WMUR 9 ABC is to the north east , so no need to receive with the DB4e. WCVB 20 is to the south east will be received buy the DB4e. Aim the DB4e at about 145 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. All of the receivable digital Tv stations/channels to the south - south east are UHF channels , so the DB4e , http://www.antennasdirect.com , will do a real fine job. As far quad coax goes . "quad" "quad coax" "quad shield" have become buzz words , it sounds cool and impressive to say. Yes quad shield does have uses as an example, at high interference locations and situations. Satellite system dealers/installers are using more quad shield because of the ever increasing amounts of wireless devices that use the frequencies that are used to transfer signals on the coax from the dish to the receiver.
Old 24-Feb-2012, 11:27 PM   #4
LOTL
Thanks Guys,
The DB4e looks to be pretty affordable. I see that it also comes bundled with a J mount and even with an amplifier. I take it since neither of you mentioned the use of an amplifier or pre-amp, then i should be all set without one for now.
If i choose to just lean it against the wall and it does well, then i can probably just whip up some inexpensive Rigid EMT Pipe mount or something similar, just to allow easy rotational movement.
Would i need to take into consideration the elevation or angle of the antenna or does that only pertain to Satellite dish placement?
Dont Multi-Directional antennas have less range than directional antennas and arent they subject to more interference?
Im assuming a Directional antenna would require the need for a rotor of some kind to get the best signal from some of the stations. I take it that seeing as how the azimuth of a lot of the stations are around 117 degrees, that i wouldnt have to move it much. This is all new to me and im learning as i go.
Electron, why 145 degrees?
GroundUrMast, great thread on the Homerun stuff. I see your running the same HRHD3 that im looking at. Is it still working well for you with the exception of only the one input?
I like what one of the other guys suggested about locating the HDHR3 near the Antenna and make a CAT5 run down to the router.
Has me rethinking the cabling of things. Although if the older Coax thats in the walls does the trick, then there's no reason to snake a CAT5 run down 3 floors in a very inaccessible house.
Not to dilute this thread, but i have been running XBMC as my media center software and have looked into various backends to do the DVR stuff. XBMC's DVR support requires a few hoop jumps and i may just go with NextPVR or maybe MediaPortal. I tried Win7 Media Center, but it choked when i added my 113 movie library plus TV show collection to it. Could just be a glitch with my Quad-core I7 system, but i doubt it
Old 25-Feb-2012, 1:56 AM   #5
MisterMe
Don't overthink this. Electron has given you excellent advice. The parabolic reflecting dish for a satellite antenna is required because it is designed to receive extremely weak signals. You can receive most of your Boston stations with a set of rabbit ears and a UHF loop.
Yes. However, this is an issue with weak signals. Electron has recommended antennas that are more than up to the task of providing stable signals to your TV.
The 145° direction is a good compromise direction that will ensure that you receive ample signal strength from Boston while allowing you to receive weaker signals from New Hampshire.
Old 25-Feb-2012, 3:39 AM   #6
The half power forward beam width of the antenna is 60 degrees , thats the angle to the left and right of the front of the antenna , a 60 degree spread to the left and right. The angle of the tv stations is 65 degree , About 145 degree antenna aiming puts the antenna about in the middle between , WHDN 120 degrees and WUNI 185 degrees. . As all ways the antenna is turned to the left and right as a final adjustment to find the best position to get the best signals of the tv stations that one will like to receive. Mister Me means well and he is doing his best help.
Old 25-Feb-2012, 3:47 AM   #7
An antenna mount like this , as an Example , http://www.ronard.com/909911.html , makes a great stand. Does Not need to be bolted the floor in side of a room. Also it will help reception if the antenna is placed at a window that does not have a real metal screen or metalized film and the direction of the window is south east or something close to south east.
Old 25-Feb-2012, 3:50 AM   #8
A tripod stand will make it easy to pick up the antenna and tripod and aim the antenna to the north east to check out reception of the tv stations of that direction.
Old 25-Feb-2012, 4:58 AM   #9
Mister Me is very preseptive he looks at letters of the alphabet the word structure and usage of words of the question askers and reaches out across the internet to understand what the question asker is really saying. When I recommended the DB4e , I recommended only the DB4e. The amplifier that comes in the bundle is the PA-18 preamp that is used when the very strongest signal is -> weak and the rest are even weaker. Your strongest signals are just enough that the PA-18 might overload and be the cause of bad or no reception of some channels. For a preamp I recommend a CPA-19 preamp it tolerates higher signal strengths and has the same gain figure. Thank you Mister Me.
Old 25-Feb-2012, 5:08 AM   #10
LOTL
More over thinking...
O.K. here is another what if. As i mentioned in my first post, we plan on selling this house and moving up to my house when it sells.
My property has very tall pine trees on either side. I have seen neighbors locate their satellite dishes away from tree coverage and run coax back to their house. (would be about a 100' run in my case)
I suspect that would be something i might have to do to get adequate reception (if in fact that direction is where the antenna needs to be pointed)
Heres my TVFool report for that location:
The other house
Would the DB4e still be the antenna of choice for that location with the possible use of a pre-amp? Or should i just worry about my present location and revisit the issue 2-3 years from now?
Thanks for the link to the tripod, i looked at a stand on Antenna Directs website and i believe it has the same dimensions as some of my speaker stands i use for DJ'ing. I have a couple old stands that i dont use anymore and it looks like one of them would do the trick.
Old 25-Feb-2012, 5:49 AM   #11
At the new location the same tv stations will be received , however the Tv transmissions to the south east and north east are A Lot Weaker. Make two more radar plots with the antenna at 40 feet and 60 feet.
Old 25-Feb-2012, 6:09 AM   #12
LOTL
Other House 40'
Other House 60'
Old 25-Feb-2012, 7:37 AM   #13
Ok it is fun to play 'what if' here at tvfool. If the Tv stations/channels stay the same in the future , all UHF digital channels , 14 thru 51 UHF , to the south east. Then use the same DB4e UHF antenna pointed at about 145 degree magnetic compass. Use a Channel Master CM7777 preamp with the DB4e antenna connected to the UHF input of the CM7777. Also there is digital Tv station that is just on positive side of the edge of being able to receive , WVBK-CA digital 2 in the VHF low band of channels 2 thru 6. The programing is , http://www.wvbktv.com , http://en.wikipedia.org/wiki/WVBK , The Outdoor Channel. . Install and connect a Winegard HD5030 channels 2 thru 13 antenna and connect to the VHF input of the CM7777 preamplifier. . If WVBK is not received then the HD5030 antenna can be turned to receive WMUR-TV 9 ABC at about 58 degree magnetic compass. The antennas will be mounted no lower then 40 feet above the ground. And if need to go higher then that is Ok. The Tv transmissions will get stronger if need to get above trees. Trees in full leaf do a good job of absorbing UHF transmissions. Here are some places to buy antennas and etc. http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com http://www.starkelectronic.com , http://www.3starinc.com. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Old 25-Feb-2012, 1:59 PM   #14
LOTL
The trigger has been pulled!
Thanks Electron for all your help. The DB4e is on order along with my Homerun HDHR-3. Let the fun (and hopefully the savings) begin!
I notice a lot of people dont post back their results after getting recommendations from here. Ill be sure to let you all know how the Grand Plan works out.
Old 4-Mar-2012, 4:37 PM   #15
LOTL
Week Signal
Well i got around to hooking up the DB4e today. I hooked it up without the Homerun box for now.
I have a newer TV which can tune OTA channels. So my connections are as follows.
DB4e Antenna > 15' RG6 to 3rd Floor Wall Jack > RG59 from 3rd Floor wall jack down to Basement > RG59 connects to 4 way Antronics 5-1000mhz splitter (all 4 outputs are -7.5db) > Out of Splitter directly to TV is a run of 50' RG6.
My signal meter on the Samsung TV, shows 4-5 bars out of 10. There is an LNA option which is described as "Amplifies the Signal Strength for the current channel" when turned off, my signal strength drops to 1 bar.
Im considering running out to Lowes and picking up a Coax coupler. Bypass the splitter and see if it helps.
Antenna placement is very touchy and im fortunate enough to have a south facing window at which its mostly pointed at. I had my girlfriend on the phone as i adjusted the antenna position to optimize signal strength.
In the direction that the antenna is facing and about 200-300' away are some high pine trees. Im tuning in about 12 stations, but some are the same station with alternative programming. Im not able to get Fox or Channel 7. Without these, the project may be dead in the water. Its unfortunate as the channels that do come in, come in well and are every bit as good as cable.
Ill run out now to grab the coupler and see what improvement there is. The next step if there is no improvement, is to replace the RG59 with RG6 or a run of CAT6 cable. I have also been looking at MOCA adapters, but id still have to use the RG59 and i dont know if ill see much of an improvement in signal strength.
Im open to suggestions. Ill post back how the coupler works.
Old 4-Mar-2012, 5:31 PM   #16
REMOVE the Splitter. . A way to 'Prove Out' reception is to run a known to be good RG-6 coax Direct from the antenna DIRECT to the Tv , No couplers , No splitters , No nothing. One length of coax Direct from the Antenna to the Tv. If there is RG-59 coax in the walls then it has been there for a Long Time. RG-6 will transfer the signal any where through out the house. You can also move the Tv close to the antenna as a test.
Old 4-Mar-2012, 5:37 PM   #17
You can also use a Antennas Direct CPA-19 preamp at the antenna. However DO NOT and I Repeat , DO NOT use the preamp as a way to try and make up for bad RG-59 coax.
Old 4-Mar-2012, 5:57 PM   #18
LOTL
Thanks again Electron.
I just installed the coupler and my signal strength went to a constant 7 out of 10.
I rescanned my stations and im now getting 16 stations which include Fox and channel 7.
I also picked up another 4 way splitter. It doesnt say what the Insertion Loss is other than "Low Insertion Loss" on the back of the package.
Ideal 4-Way Splitter
I havent put it in yet, as the other rooms that the splitter fed aren't used.
Ill try bringing one of the tube TV's we have laying around upstairs and connect the antenna directly to it and see what it does.
Old 4-Mar-2012, 6:11 PM   #19
Your plan of connecting the antenna directly to one tuner is a good one. If it's not too much trouble, I would carry the TV up to the third floor, close to the antenna. The idea is to determine the quality of the signal at the output of the antenna, before any old coax, amplifier noise or splitter loss complicates the situation.
If you have a good signal at the antenna, then you can expect to find a reliable solution for distributing the signal.
An amplifier can only use the signal available at it's input. So, an amplifier at the end of the line is at a disadvantage compared to one close to the source. The CPA-19 suggested earlier is definitely worth consideration if you need to overcome cable and splitter losses.
But again, be sure you have a usable signal at the antenna before you add other factors.
The idea of using Ethernet over coax adapters is very viable. I would add that complexity only after I had the basic antenna and distribution system running reliably.
Also, be on the lookout for loose or otherwise faulty connections on the old coax... those old crimp connectors were a constant source of trouble, even when assembled using pro-grade tools.
Old 4-Mar-2012, 6:26 PM   #20
LOTL
Well the older tube TV i brought upstairs evidently doesn't have a QAM tuner (QAM was the wrong term to use, thanks Electron for the correction). It wouldn't display any channels.
To have to carry my 50" Samsung DLP up 3 flights for the purpose of this test, has me thinking i have already gotten the stations i was hoping for and that i should be happy with that.
I guess if i want to distribute the signal to the other unused rooms at some point, then ill have to try the splitter i picked up or another option.
Im sure i wont leave things as is and ill wait for my girlfriends son to get home and have him help me carry the TV upstairs. Stay tuned...
