Old 17-Feb-2012, 1:22 AM   #1
bhaines23
Need Help - Can't get any channels
Here's my report:
http://www.tvfool.com/?option=com_wr...0b86420e1094df
I'm very interested in cancelling my cable television since I don't watch much TV except during football season (I'd probably get cable tv again during the season).
I live in a townhouse, end unit, with my neighboring unit being to my NW direction. I have two TV's I'd like to get reception, the one in my bedroom faces the NE direction, and the one in the living room is on the SW side of the house.
I bought the RCA Antenna ANT111 from Amazon and I tried it on both of my Samsung TV's. I had the TV set to AIR (not Cable) and I tried auto scan. No channels were picked up.
Am I doing something wrong or does my location prohibit me from picking up anything with an indoor antenna? I saw reviews for the Mohu Leaf antenna and thought about trying that, but I don't have high hopes.
The channels I'd like, ignoring their signal strengths, are CBS, FOX, ABC, NBC. But at this point any channel would be great!
Thanks for any help!!
bhaines23 is offline   Reply With Quote
Old 17-Feb-2012, 9:34 AM   #2
To receive 2 or 3 digital tv channels. Put the ANT111 in a , north , north east , east window. The tv needs to scan for , Digital Broadcast Tv Channels , sometimes called the 'air channels'. If you will like to receive Many More Digital Tv Stations/Channels. Install a Winegard HD7696P antenna with a Winegard HDP-269 preamp on the roof aimed at about 139 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com . Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com. . Type the word , ronard , in the solidsignal search box or buy from Ronard.
Old 17-Feb-2012, 5:54 PM   #3
MisterMe
To follow-up on Electron, your primary problem is that you have obstructions between you and your best transmission towers. You can't fix your situation, but can make it better. You need an outdoor antenna mounted at least 20 feet above ground-level. If you can raise it above 20 feet, the higher the better. Redo your TV Fool Radar plot. You will see that as your antenna goes higher, you will convert several stations from red to yellow.
