Old 17-Feb-2012, 12:28 AM   #1
oldjake135
Smile antenna
http://www.tvfool.com/?option=com_wr...0b86c3990ab330 i was checking out this channel master ultra-hi crossfire antenna numb 3671, will it work as good as a wineguard 8200u not sure wich one is best for my area thanks for any help
oldjake135 is offline   Reply With Quote
Old 17-Feb-2012, 1:24 AM   #2
http://forum.tvfool.com/showthread.php?t=2512. Still on the fence?? Yes the CM3671 will get the same reception as the HD8200U. The tvfool data base is not up to date for the Canada Digital and Analog tv stations/ channels. Go to http://www.digitalhome.ca for up to date tv stations/channels of your area. A CM3671 antenna with a Antennas Direct CPA-19 preamp and a CM9521A rotor will receive all the channels of every direction. Also check with , http://www.saveandreplay.com
Old 17-Feb-2012, 3:35 PM   #3
oldjake135
Smile Electron
thanks for your help , yep still sitting on the fence, price wise channel master is cheaper, anyway not going to do much with it till it warms up i am using a pa 18 amplifier by antenna direct , will that work as good as a pa 19 ? thanks again
