I just ordered the Antennas Direct DB2 and want to install it it in the attic when it arrives. Here's my problem: When my house was built I installed some extra coaxial cable for the TVs. Most of the cables carry the Comcast signal from a four way splitter to the various rooms in the house. However there is one cable that runs from the living room to the master bedroom that I installed thinking I might need it for something one day. That day is here. I want to use it to hook these two TVs to the new antenna.
The problem is everything is covered in about a foot of blown in insulation. I think I've found the middle of this cable but I'm not sure. If it is the right one I want to cut it in the middle and hook the antenna with a splitter to the two TV's. Is there some kind of test I can perform on it to make sure it's the right one?
