Old 9-Feb-2012, 12:47 AM   #1
Ralph
Antenna recommendation needed
http://www.tvfool.com/?option=com_wr...0b8675789700b2
Please give me your recommendation for an outdoor (1 or 2) antenna.
I want to receive high vhs and uhf from a cluster of staions aboutv 25 miles away. Would a 2 or 4 bat antenna be better than a yagi type antenna?
Ralph is offline   Reply With Quote
Old 9-Feb-2012, 3:36 AM   #2
If the house is wood frame with wood or vinyl siding and has no foil backed insulation , then a Channel Master CM 4010 or TERK HDTVi non amplified indoor antenna aimed at about 275 degree magnetic compass will receive all of the tv channels. Here is how to aim indoor non amplified antennas. http://www.kyes.com/antenna/pointing/pointing.html . . If the house is , concrete , concrete blocks , cinder blocks , bricks , metal frame , metal siding , stucko Wire , foil backed insulation , metal roof . solar panels , then the reception will be reduced or blocked. Install a ANT751 antenna above the roof aimed at about 275 degrees magnetic compass. The tv must scan for , Digital Broadcast Tv Channels , sometimes called 'air channels'. Do Not scan for cable tv channels.
Old 9-Feb-2012, 3:38 PM   #3
Ralph
Thanks for the standard reply. I have seen it before but I would perfer that you address my situation directly. The term bat should have been bay. thanks again.
Old 9-Feb-2012, 5:49 PM   #4
Standard Reply , Now thats an interesting comment. Your location has the UHF channels and also the VHF high band channels , 7 , 8 , 11 , 13 , to receive in the directions of north west and west. Install a http://www.winegarddirect.com , HD7694P or http://www.antennacraft.net , HBU22 or http://channelmasterstore.com , CM2016 or RCA ANT751
Old 9-Feb-2012, 9:20 PM   #5
A few building materials are better for indoor tv reception. So yes that is a Standard Reply.
Old 9-Feb-2012, 9:22 PM   #6
There are building materials that reduce or block tv reception. So yes that is Standard Reply.
