Old 4-Feb-2012, 4:03 PM   #1
sugewhite
HDTV antenna selection for boxee tv
Good morning. I recently got a boxee live tv(trying to cut the cord). I get 38 channels with the antenna included but I am not picking up a few channels that are local. I am looking for an indoor antenna because I do not want to mess with any wiring installing etc... Here is my TV Signal Analysis Results:
http://www.tvfool.com/?option=com_wr...0b86d17c49b4e6
Please let me know what you think. Thanks
sugewhite is offline   Reply With Quote
Old 5-Feb-2012, 6:34 AM   #2
If the house is constructed of wood with wood or vinyl siding with no metal backed insulation , the reception is easy , install a Channel Master CM4010 Non amplified antenna or Terk HDTVi , Non amplified antenna. Aim the indoor antenna at about 0 degree magnetic compass. Here is how to aim indoor tv antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Old 5-Feb-2012, 6:55 AM   #3
If the building is/has , concrete , concrete blocks , cinder blocks , brick from ground to roof , metal framing , metal siding , stucko Wire , metal roof , solar panels , metal backed insulation , reception will be reduced or blocked. And a outdoor roof top antenna , a , ANT751 can be installed and aimed at about 0 degree magnetic compass. For better reception.
