Old 5-Sep-2010, 3:00 PM   #1
SCREENWRITER
Question regarding number and type of Antenna, as-well-as height.
Any sugestions will be appreciated.
I am located in Diamondhead Mississippi. The New Orleans stations are aprox 65 miles West. Biloxi--30 miles East. Mobile--90 miles East. Aproximately 35 feet above sea level.
Mounting on my roof is not an option. I do have a lot of attic and the attic height is aproximately 70 feet above sea level/25 feet above ground level.
I do have an antenna "pole." And, it is a 6 inch diameter pipe that is 11 feet tall; it is grounded and there is a 120v power supply at this pole. Also, I have the capability of getting another 6 feet out of this pole.
I am looking at the advertising associated with this site and am using the advertising as a starting point in looking for an antenna, however, I would appreciate any of you who read this to suggest specific Antennas, and boosters. Also, I am assuming the antenna turns in the direction of the broadcast signal, so, anything that you all may suggest with regard to turning devices would be greatly appreciated.
Best Regards,
Billy
SCREENWRITER is offline   Reply With Quote
Old 5-Sep-2010, 10:01 PM   #2
Tv reception
Your post / question goes to the Help With Reception Part of tvfool.http://forum.tvfool.com/showthread.php?t=4
Old 6-Sep-2010, 11:06 AM   #3
Thread moved to correct forum area
Old 7-Sep-2010, 1:21 AM   #4
We need to see your TVFool report. Follow the instructions that John linked to.
