Old 21-Jan-2012, 3:51 AM   #1
hub
antenna advice
rabbit ears will get me abc, but i would like to get (at least) nbc, cbs and fox as well. tried a very old, damaged outdoor antenna with no results and would like some advice before spending money on a new antenna.
thanks!
here's my map...
http://www.tvfool.com/?option=com_wr...67d9f840a28a78
hub is offline   Reply With Quote
Old 21-Jan-2012, 4:14 PM   #2
Reception of KETK-NBC calls for an outdoor mounted antenna. A Winegard HD7698P and Antennas Direct CPA-19 is one option. Point toward 325° to begin with.
If you have nearby trees, you'll benefit from additional mounting height if you are able to do so practically and safely.
http://www.antennasdirect.com/
http://www.winegarddirect.com/
http://www.3starinc.com/
http://www.amazon.com/
Old 21-Jan-2012, 4:37 PM   #3
hub
Thanks for the help!
Old 21-Jan-2012, 5:08 PM   #4
For the reception of , KHTM-LP 13 / KIBN-LP 14 / Family Network , KTRE 9 ABC , KFXL-LP 29 FOX , KLNK-LD 48 Famila Network , KLNM-LD 42 TBN , KYTX 18 CBS , KETK-DT 22 NBC. And the digital sub channels of the listed channels. Install a Winegard HD7698P antenna with a Winegard HDP-269 preamp aimed at 330 degree magnetic compass. The HD7698P antenna receives channels 7 thru 13 and 14 thru 69. KHTM is on channel 13 , KTRE is on channel 9 so your location needs a antenna that receives both VHF Hi channels 7 thru 13 and UHF channels 14 thru 69 -> the HD7698P antenna. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
Old 21-Jan-2012, 5:37 PM   #5
hub
thanks guys... ya'll have been a big help... i'm getting rid of cable in a couple of weeks and needed the advice!
