Old 31-Aug-2010, 4:24 AM   #1
Billiam
Rotor Question
I would like to mount a 10 foot mast on top of a rotor and then add a 91XG antenna and YA-1713 under it. I've read where a couple of people have tried this with success when using he Channel Master 9521 rotor.
Has anyone tried it with that rotor?
Another option would be to purchase the U110 from Norms. Has anyone tried using this rotor with a 10 foot mast and two antennas?
http://www.rotorservice.com/images/U110RC%20Nw.jpg
Old 31-Aug-2010, 8:01 PM   #2
To minimize stress on the rotor and maximize its life, it's always best to try and minimize the length of the mast above the rotor. The stress levels go up approximately with the square of the length of mast, so any height you can eliminate will really help.
Just a few comments:
1) If all you want is the 91XG and the YA-1713, then you can probably get away with less than 10 feet of mast. If you keep about 4-5 feet of separation between the antennas, you can probably get away with about 6 feet of mast.
2) The 91XG and YA-1713 are both relatively light-weight antennas. As long as the mast above the rotor is kept short, the CM 9521A should work fine with this kind of load.
3) For taller masts or heavier antenna loads, you need to use a rotor alignment bearing and guy wire stabilization above the drive unit.
Old 1-Sep-2010, 1:57 PM   #3
Billiam
^^^Thanks. That makes sense.
