Old 7-Jan-2012, 1:54 PM   #1
lorens
reception question
I can receive channel 49.1 kpdx perfectly, I get 22.1-3 when the sun is up. I also get 5 and 14 but not good enough to use. I have a vhf/uhf yagi roof top sighted to 145 degrees, I have a preamp at the antenna to boost signal strenght. Any clues as to why I can't get the rest which apper to be stronger stations.
http://www.tvfool.com/?option=com_wr...7fb994f433ff58
see above link for charts from tvfool.
Loren
lorens is offline   Reply With Quote
Old 7-Jan-2012, 2:31 PM   #2
The transmitters at the top of the list are Weak , and as go down the list , have less and less power. Make two new tvfool radar reports , antenna heights of 40 feet and 60 feet. For stronger reception.
Old 7-Jan-2012, 5:56 PM   #3
MisterMe
It appears that your "VHF/UHF Yagi" antenna is actually UHF-only. Otherwise, you would not receive UHF KPDX while not receiving 20 dB stronger VHF KGW and the other VHF stations in your radar plot.
Old 7-Jan-2012, 6:44 PM   #4
Do you know the make and model number of your antenna?
