Old 27-Aug-2010, 5:46 PM   #1
dgpcolorado
Western Colorado correction
I believe that the signal analysis for the area near Montrose Colorado is incomplete or incorrect. The location known as Waterdog Peak has a RMPBS (Rocky Mountain PBS) translator that broadcasts on virtual channels 18.1, 18.2, 18.3, and 18.5. It might be the translator that the TV Fool database shows as K61BR channel 33, virtual 61.1.
Whatever the actual ID of the translator, I can say that it does not broadcast as virtual channel 61.1 (61 used to be the analog channel for RMPBS in the area, hence the "K61BR" ID). It does broadcast as 18.1 and is PBS. The position of Waterdog Peak is 38°23′12″N 107°40′31″W. FWIW, I get no other digital TV signals from this location.
dgpcolorado is offline   Reply With Quote
Old 29-Aug-2010, 1:48 AM   #2
Thanks for the update!
You are right that the transmitter is going by the callsign K61BR. We've updated the database to include the correct virtual channel and network affiliation.
FYI, these changes should take effect immediately on any newly generated reports.
Old 29-Aug-2010, 3:50 PM   #3
dgpcolorado
^You're welcome. I appreciate the work done to make this site such a useful resource.
Old 8-Nov-2010, 3:20 PM   #4
dgpcolorado
Some more western Colorado updates
• Channel 9 Ouray ceased broadcasting in analog in June and began broadcasting in digital in October.
•The Montrose Colorado transmitter for KREY handles both CBS and Fox.
Verified
K09PJ Ouray Channel 9, digital:
virtual 18.1 KRMJ, Rocky Mountain PBS
virtual 18.2 V-ME, Spanish language PBS affiliate
virtual 18.3 Create, PBS affiliate
Verified
KREY Montrose Channel 13, digital:
virtual 10.1 KREY CBS (KREX, Grand Junction, affiliate)
virtual 10.2 KFQX Fox
I can't receive the following because of the terrain but know this is a Rocky Mountain PBS translator:
K31IW Ridgway Channel 31, digital
Probably:
And, as reported previously:
Verified
K61BR Waterdog Peak, Channel 33, digital:
