Old 26-Aug-2010, 4:25 PM   #1
kenais
Selection help in NW Wisconsin
http://www.tvfool.com/?option=com_wr...9fbe6e0d6f7a13
Here is my report. My house is slightly downhill from the surrounding area and there are many trees to the north west and east. I do have a high peaked roof.
I'd like to receive the channels from the SW and at least WEUX to the SE.
Can you help me with equipment selection?
kenais is offline   Reply With Quote
Old 26-Aug-2010, 7:05 PM   #2
Hello and welcome!
Are you absolutely set on getting WEUX? There is another Fox affiliate, KMSP (channel 9), that is located in the same place as all the other transmitters in Minneapolis.
If you stick with only the Minneapolis stations, then your antenna setup will be very simple. Just point an antenna like the Winegard HD7694P or Antennacraft HBU-33 toward compass heading 231ยบ and you're done.
If you really want stations from both the Minneapolis and La Crosse-Eau Claire markets, then you will need to use an antenna rotator -OR- install two antennas and combine them. You can get stations from both metros, but there are consequences to consider with either of these solutions.
Unless you have a pressing need for WEUX, I would just go for the Minneapolis stations.
Old 26-Aug-2010, 7:43 PM   #3
Billiam
^^^My guess is that he wants to watch the Packers and not the Vikings. :-)
Old 26-Aug-2010, 8:52 PM   #4
From the SW: Antennacraft HBU-22 or Winegard HD7694P
WEUX: any UHF only antenna, but the 91XG will work better than anything else.
Ad them together with a Jointenna tuned to channel 49. http://www.warrenelectronics.com/Ant...Jointennas.htm
This will work for one or 2 TVs. If more are needed add a preamp or distribution amplifier.
There are other ways to do the same thing, but this solution is an exact answer to your question.
Old 26-Aug-2010, 9:03 PM   #5
kenais
Spot on with the Packers, that is the only reason I'd like to receive that station. Seeing Farve twice a year is enough. I'd also like to get the ABC affiliate from LaCrosse/Eau Claire to pick up the Badger games. Any additional channels from Wisconsin would be a bonus.
I have 2 TVs in my house I'd like to hook up.
Would I be better off with a rotor or 2 antennas? I figured I would probably need a pre-amp.
Old 26-Aug-2010, 10:50 PM   #6
tv reception
An easy way to do it is two seperate antennas and seperate coax to each tv and remote control A/B coax switch box at each tv. Radio Shack has the remote control A/B switch box. For the antennas a winegard HD7694P pointed south west and a winegard HD7696P pointed south east. No pre amplifiers are needed with the antennas. No pre amplifiers are needed . http://www.solidsignal.com
Old 27-Aug-2010, 2:53 AM   #7
Billiam
It may be a while before you see a Jointenna. I ordered one at the end of March and when I called Warren a couple of weeks ago to find out what happened, they told me they were still waiting to receive them.
Old 30-Aug-2010, 4:16 PM   #8
kenais
Thanks for the advise, that looks like a nice set-up for me.
Just to make sure I understand this... I run a coax from each antenna to inside my house. Then install a 1-2 splitter. Then 2 coax to each TVs switch box. Is that correct?
There will be about 60' of cabling for each TV. Sure those antennas are large enough?
