Old 2-Jul-2010, 2:56 PM   #1
PALMVALLEYBC
Citv-dt
Reference info database gives vancouver bc tv channel civt-dt id as 33.1... Should be id od 32.1 .. Note.. When civt analog 32 stops transmission in 2011, citv-dt will revert to rf channel 32 and will retain id of 32.1. ..........cheers
PALMVALLEYBC is offline   Reply With Quote
Old 29-Aug-2010, 12:25 AM   #2
Thanks for the update!
FYI, these changes should take effect immediately on any newly generated reports.
Old 23-Feb-2011, 2:30 AM   #3
MoreDb
CIVT no listed
Old thread, but just noticed today that RF33 (CIVT) is not being displayed at all. As stated, CIVT presently broadcasts RF33 remapped to 32.1, and after August 201, it will change to RF32 and 32.1.
I just noticed today, that CIVT DT is not showing in the data base search result for all Vancouver locations.
MoreDb is offline   Reply With Quote
Old 23-Feb-2011, 4:30 AM   #4
This is probably a result of the latest influx of Industry Canada data changes. All "OP" and "TO" records have been added to the "current" analysis. All "AU" and "AP" records have been added to the "pending" analysis.
It looks like CIVT-DT on channel 33 is an "AU" record, so it should be showing up in the "pending" list of channels.
If this transmitter is already live, then we can move it to the "current" database.
It will probably take a while to sort out which of the "AU" transmitters are already on the air. If anyone is aware of "AU" transmitters that are already live, then please let us know so we can update the lists. Please bear with us while these changes get worked in.
