Old 30-Jun-2010, 2:20 PM   #1
andrewsignore
Honestly, Is it worth it for me?
I'm new to this scene but I just ran my report and I think its looking ugly.
http://www.tvfool.com/?option=com_wr...9fbeb79b66a424
I really want to cut the cable ASAP but good reception is important for me. If I can't get cbs, nbc, abc and fox in HD then its a deal breaker. I'm willing to invest in a high powered antenna, amplifier set top boxes etc if I knew I'd be able to watch OTA HD network broadcasts. What do you all think?
Thanks in advance for the advice!
andrewsignore is offline   Reply With Quote
Old 30-Jun-2010, 3:02 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
It isn't all that bad: yes, you have hills blocking the Empire State Building where you are, but the NYC stations are all in positive noise-margin numbers: you should see all the major NYC stations with the right antenna system.
This is a situation where I would use my deep-fringe prescription: I have posted it before, but I will link it here so you can use it.
http://www.hdtvantennalabs.com/forum...226.html#p4476
sorry for posting from another forum, but I can't seem to find the post here.
Old 30-Jun-2010, 4:05 PM   #3
andrewsignore
Thanks Tigerbangs! Glad to hear it's not a lost cause. I saw in your post that you listed 3 antennas in the equipment list but the picture illustrating the setup only seemed to have two and two of the antennas looke to be the same type;
Winegard YA 1713 Prostar 1000 10 El. Hi-Band VHF TV Antenna (YA-1713)
Antennacraft Y10-7-13 Highband-Broadband VHF TV Antenna (Y10-7-13)
Is this an either or situation or would I require both (n addition to the UFH antenna). Please excuse my ignorance if this should be obvious. Thanks again for your help.
Old 30-Jun-2010, 4:11 PM   #4
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
No Problem!
The AntennasDirect XG-91 is a UHF only antenna: the Winegard YA-1713 and the AntennaCraft Y-10-7-13 are VHF antennas. I gave a choice between the two VHF antennas, but recommended only the AntennasDirect XG-91 for UHF, so it's an either/or situation on VHF.
Old 30-Jun-2010, 7:55 PM   #5
andrewsignore
one other question. Since it seems all of the stations I'd like to receive are in the same direction, would I still need a rotator on the antenna?
Old 30-Jun-2010, 8:50 PM   #6
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
if you are only interested in the NYC stations, then you don't need a rotator: you will just have to aim the antenna array once, and you'll be fine.
