Old 27-May-2010, 6:44 PM   #1
22350
Reception in Los Angeles
Hello Everyone,
I have just tried for the first time to use DTV.
I purchased a box and amplified antenna from radio shack.
Almost no channels come in. I am missing 11, 9 ,13, and a bunch of others.
I tried to make one of the home brew antenna:
I am in the middle of Hollywood California and can't get reception.
http://www.tvfool.com/?option=com_wr...9fbef6d3742056
Starting to think this DTV is a scam.
Am I missing something?
Paul
22350 is offline   Reply With Quote
Old 27-May-2010, 7:46 PM   #2
Try loosing the amplifier. Place your antenna in a window that faces north-east and re-run your channel scan.
Old 27-May-2010, 8:37 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
remember that Los Angeles has 4 major VHF digital TV channels; KABC, KCAL, KTTV and KCOP: neither of the antennas that you have pictured is likely to be able to see those stations well. Is there any possibility of mounting an antenna on your roof? You should be able to see tons of stations if you do...
Old 27-May-2010, 11:03 PM   #4
Tv reception
You Do Not need a antenna amplifier , the signals are so hot that the amplifier WILL Overload and blank out the reception. The signals are so hot that any piece of wire will give many channels. . So what is your living situation , do you live in a steal box? Are there any windows or patios with this steal box that face the transmitters. Is the coax cable defective , is the converter box defective , is the tv defective.? . Do you live in Apartment , Condo , First floor , second floor 3,4,5,6,7, floors. Do you live in a house? Is the building made of concrete?
Last edited by teleview; 31-May-2010 at 11:56 PM. Reason: Spelling corrections and update/clarify information.
