Old 4-May-2010, 5:25 PM   #1
relepper
relepper
Wesley Chapel, Florida (24 miles NNE of Tampa)
Hi, looking to 'cut the cable' and would appreciate any advice for antennas and mast height. I have a two story home with pretty much no obstructions all the way around. I had the home prewired for Satellite/Antenna and have five home run coax leading to a main junction box inside the house. The junction box has out 110 outlet and I had coax and Cat 5 run absolutely everywhere. I'm currently on Verizon FIOS for internet, phone and TV and want to do away with the TV and Phone but keep the internet.
http://www.tvfool.com/?option=com_wr...cd72cb82f9e0f6
All advice much appreciated.
Thanks,
Rick
relepper is offline   Reply With Quote
Old 4-May-2010, 11:21 PM   #2
Thanks,
Rick
One antenna for WTSP, perhaps a Y5-7-13 plus a channel 10 Jointenna.
A second antenna for the others, HBU-22 or HD-7694P.
Height is not critical.
Old 5-May-2010, 3:47 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Exactly what Tower Guy said, but a bit more explanation: Aim the broadband antenna ( the Winegard HD-7694P or the AntennaCraft HBU-33) at 170 degrees as measured by your compass: aim the AntennaCraft Y-5-7-13 at 270 degrees, and use a channel 10 Jointenna to combine the two antennas into one downlead. Be sure that the antennas are separated on the mast by at least 4', and you'll be fine. Jointennas are available very cheaply on Amazon.com:
http://www.amazon.com/Channel-Master...3074182&sr=8-3
Here are links to the recommended antennas:
http://www.winegard.com/kbase/upload/HD7694P.pdf
http://www.antennacraft.net/pdfs/HBU33.pdf
http://www.antennacraft.net/pdfs/Y5-7-13.pdf
And here is a good antenna installation guide:
http://manuals.solidsignal.com/AntInstallGuide.pdf
Old 5-May-2010, 10:38 PM   #4
Thanks for the verboseness.
