Old 23-Apr-2010, 8:29 PM   #1
darlee
Help with reception in OC
I have try to reply to my own thread the site it wouldnt let me, so I am starting a new one.
we just moved to a new place in Aliso viejo California the signal here is horriable i wanted to know if there is anyway I can connect two antenna and feed the signal into are tv with one cord?
Also the antenna I got its the channel master 4228 i am not sure if its the right anntenna for us we are in between two canyons let me know if there is a better antenna out there I should get.
here is my TV Fool report
http://www.tvfool.com/?option=com_wr...9c6b06bad00852
darlee is offline   Reply With Quote
Old 24-Apr-2010, 10:51 AM   #2
kb2fzq
First off, of the top 5 stations on your TVFool report (the strongest signals), 4 are VHF stations, your antenna is a UHF antenna, and at roughly 50 miles away, you will be hard pressed to get those VHF stations with your antenna.
I would get a VHF antenna, and use a UVSJ signal combiner to connect to 2 antennas together.
The antenna gurus will eventually pop in here to give you their choices for a setup.
