Old 27-Dec-2011, 8:13 PM   #1
cuffs558
Trying to help my mom find an antenna...Please Help
Just to let you know, I have no idea on what the heck to do or get. Since she is not working any longer tv has to go. I would like to help but need help in picking an antenna for her....
Thank you for your interest and help!!
this is the result i had gotten from tvfool
http://www.tvfool.com/?option=com_wr...4033851f76f471
cuffs558 is offline   Reply With Quote
Old 27-Dec-2011, 8:41 PM   #2
Tv reception with tv antennas
A simple and easy reception situation. Install a Winegard HD7698P antenna above the roof. Aim the antenna at about 226 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.solidsignal.com , http://www.amazon.com. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html
Old 27-Dec-2011, 9:24 PM   #3
I agree with the antenna suggestion, and would add a recommendation for a preamp.
Either the Antennas Direct CPA-18 or the Winegard AP-8700 with the CPA-18 favored due to it's excellent noise performance.
Old 27-Dec-2011, 11:24 PM   #4
cuffs558
thankful
Thank you for both replies. I will start making a list of items needed for everything to approach her with the solution. There should be someone in the area that knows how to put it up for a trailer. Very grateful for your help....
Old 28-Dec-2011, 1:23 AM   #5
Recommend new, standard , RG-6 coax on the outside thats exposed to the weather. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html. Do not have the antenna hugging the trailer , it is a good idea to have the antenna a minimum of 3 feet higher then the highest point of the trailer. Mount the antenna in a way that is Strong and Sturdy.
Old 28-Dec-2011, 6:14 AM   #6
cuffs558
Smile thanks for the extra
thank you very much for the extra knowledge.... very grateful!
