Old 29-Dec-2009, 4:32 AM   #1
Rosa
My converter box makes a great weather station!
Here is my tvfool report:
http://www.tvfool.com/?option=com_wr...4105118eb1bf6e
I have an RCA converter box, and a UHF/VHF antenna, which has an amplifier.
I was watching the available DTV channels for a year or two before the transition. After the transition, several of the Bay Area stations moved the location of their broadcast antenna on Sutro Tower in San Francisco, work that wasn't completed until October. I lost ABC7 KGO-DT for a while after October, but I can get it most of the time now. I regularly have to rescan and sometimes even do the power off thing, which is supposed to clear the converter's memory.
It seems to me that certain weather patterns interfere with the reception. Is that possible with DTV? I can pretty much guarantee that about 20 minutes after the picture starts pixelating and the sound starts popping, the wind will get up and rain will fall. That's about the time it takes for a weather cell to cross San Francisco Bay.
ALSO, I have never been able to get KNTV-DT (NBC). It's transmitted from a different tower down in the South Bay. Yet, I can get KFTL-CA, which seems from your Google Earth map to be transmitted from a tower in nearly the same location. How important is the angle at which the signal leaves the transmitter?
Another question, do TV stations increase/decrease their power at certain times of the day? Could that be a factor in reception?
Thanks,
Rosa
Rosa is offline   Reply With Quote
Old 29-Dec-2009, 8:06 AM   #2
Hello and welcome!
Yes, KGO was broadcasting with lower power for a while, but things should be better now. They are on a VHF channel, so if you antenna is not good at handling VHF channels (some antennas that say VHF are not actually that good at VHF), that might be part of the problem. KGO is quite strong at your location, so the right antenna should be able to pick it up easily.
Do you know the make/model of your antenna?
Yes, weather can affect signals. The water in the air can absorb a little of the signal energy. Another common phenomenon is that trees in the path of the signal get wet and become better signal blockers due to the increased water content. This was true even in the days of analog television.
If you can visually observe these weather-related signal dropouts, it usually means that your signals are operating near their minimum levels. If losing a small amount of signal causes a channel to go away, then it means the channel has dropped below its operating threshold (the so-called digital cliff). If you can improve the signal strength and/or quality reaching your receiver, then you'll have more margin for error when dealing with these external influences (seasonal changes, storms, interference, etc.).
A better antenna might fix some of your "borderline" channels.
KNTV is being broadcast from San Bruno, which is just a little south of San Francisco. It's about the same distance and about 20 degrees further to the south than Sutro tower. It is also broadcasting on VHF (channel 12), which makes me think that maybe your antenna's VHF performance is really not what it should be.
FYI, KFTL-CA is also broadcast from San Bruno.
It is very important. Many broadcasters use directional antennas, so their emitted power is not equal in all directions. In some cases, the broadcaster must try to minimize power in certain directions to prevent interference with stations in neighboring markets. So a 1 megawatt transmitter does not mean that it emits 1 megawatt in all directions. You may, in fact, be seeing much less than the "peak" power that a station claims.
The signal analysis tools at tvfool already take this into account. If you are receiving signals from "directional" transmitters, your angle with respect to each transmitter has already been factored into the equations.
That used to be a common practice, but is not so common today.
What you will see more often is that the changes in the atmosphere will cause signal increases and decreases throughout the day. Sunspot activity and meteor showers can also have an effect. There can be some days when you might receive channels from usually great distances (sometimes hundreds of miles away), which is a hobby/sport that is sometimes referred to as DXing.
Old 30-Dec-2009, 1:50 AM   #3
Rosa
Thanks for your fulsome reply!
I neglected to say in my initial post that it's a rabbit ears and loop indoor antenna, though you probably guessed that, if only because my radar map says it's 3 ft above the ground!
My first antenna was an RCA ANT301, but it didn't have an amplifier and wasn't very satisfactory. The one I'm using now is, admittedly, an el cheapo model F-6454A by Cornet.
After reading some of the information on your antenna pages, I'm thinking I'll try putting it up higher in the room on a ledge where I could put the VHF legs out flat, rather than in their current V pattern.
Old 30-Dec-2009, 1:53 AM   #4
Rosa
This could definitely be part of the problem.
Old 30-Dec-2009, 4:42 AM   #5
Do extend the rabbit ears elements about half way out ~20-25" each side. This will help tune the rabbit ears to the high VHF stations in your area.
