Old 16-Dec-2011, 2:36 PM   #1
marty slater
need help please
Tired of the mounthly cable bill
not real good at this computer stuff
been looking around hear for a while
hope this link thing works
but just incase Marion Ia 52302
marty
marty slater is offline   Reply With Quote
Old 16-Dec-2011, 2:40 PM   #2
marty slater
have 2 old tv so if you could recomend a converter box
hopeing santa will bring 1 new tv
Old 16-Dec-2011, 6:20 PM   #3
TV Fool Report from http://forum.tvfool.com/showthread.php?t=6776 --- http://www.tvfool.com/?option=com_wr...403391070aeb02
Based on this I would expect an RCA ANT-751 pointing at about 320° to receive the stations NW and SE of you. That is, if you mount outdoors and high enough that both the front and back of the antenna are not blocked by the roof or other construction.
The Channel Master CM-7000 is worth looking at. http://www.channelmasterstore.com/Di..._p/cm-7000.htm
Amazon has several STB/DTV converters, though the choices change nearly day to day it seems.
Last edited by GroundUrMast; 31-Dec-2011 at 5:57 PM. Reason: OP provided TVFR link
Old 16-Dec-2011, 6:29 PM   #4
A 2-year old TV shouldn't need a converter box. Inclusion of a digital tuner became mandatory for sets sold in the US as of March 2007.
Old 16-Dec-2011, 7:23 PM   #5
marty slater
thank you but more like 6th st an 10 th av in the neighborhood for sure
found the RCA ant751 for around 50-60$ local
the link for CM7000 sold out for now
thankyou GroundUrMast
2 old tvs need the box
thankyou ADTech
hope to be on FREE tv by the new year
marty
Old 16-Dec-2011, 10:33 PM   #6
thankyou ADTech
marty
You're right, the good old CM-7000 has been superseded by the CM-7001.
Also look at the Zinwell ZAT-970A, Digital Stream DTX9950 and Magnavox TB110MW9
Old 17-Dec-2011, 12:20 AM   #7
Just found this option re. the CM-7000: http://www.channelmasterstore.com/Di...p/cm-7000r.htm
Old 17-Dec-2011, 3:12 PM   #8
marty slater
thanks so much for your time an help
been looking in to it a little more
the house was rewired 2 mounths ago
kid used all new wire an spliters this is what i hope to do
ant RCA ant751 peack of garage
6foot of cable
CommScope Digtal spliter 5-1002MHZ SV-4G 4way(on the outlets7DB)
do i need to plug the extra outlets ?
30 foot new cable to MBr converter box an old tv
25 foot new cable to famliy room hoping new tv but
would like to go though a Philips DVD 782C DVD/CD player
then a Philips FR Digital Audio/Video Surround Receiver
marty slater
Old 17-Dec-2011, 3:39 PM   #9
marty slater
magnavox at sears for 49.99
marty
Old 17-Dec-2011, 7:02 PM   #10
Splitter ports need to be terminated with a tuner or a 75 ohm resistor. This can be done at the splitter or at the end of the cable if already run.
Old 17-Dec-2011, 11:25 PM   #11
Tv Reception with Tv antennas
Install a Channel Master CM3000A antenna above the roof. Here are some roof mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html For one tv connection do not use a splitter. For 2 tv connections use a 2 way splitter. For 3 tv connections use a 3 way splitter. For 4 tv connections use a 4 way splitter. Here are places to by antennas and etc. , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
Old 20-Dec-2011, 6:18 PM   #12
marty slater
allrighty then got the RCA 751 coming
got the Magnavox
got the 75ohm caps
will be back when get it all up an running
thanks so much for the help so far
marty
Old 31-Dec-2011, 6:04 PM   #13
A quick look at your updated TVFR confirms that you should get good results with the ANT-751.
Old 1-Jan-2012, 4:47 PM   #14
marty slater
first off thank you GroundUrMast for your help
OK my set up
RCA ant 751
6' RG6 cable [all cable RG6]
ground block [tied in to the house ground]
[1 st ? would i still need to GroundMyMast]
6' of cable to a 2 way splitter [with 1 caped with a 75 ohm cap]
[ the other will be used latter]
25' of cable to a Magnavox TB110MW9 to a Philips DVD 782C DVD/CD player
hooked up to a Philips FR Digital Audio/video Surround Receiver
to a old Philips TV an now for the results 26 channels
2.1 CBS KGAN-DT with a SIGNAL in the 70s
2.2 CBS KGAN Cool TV '' '' 70s
7.1 NBC KWWL-DT 90s
7.2 NBC KWWL-DT This 90s
7.3 NBC KWWL-DT ME TV 90s
9.1 ABC KCRG-D1 90s
9.2 ABC KCRG-D2 90s
9.3 ABC KCRG-D3 Wx Now 90s
12.1 PBS KIINHD IPTV 40s to No Signal
12.2 PBS KIINHD IPTV 30s to NS
12.3 PBS KIINSD1 IPTV Learns 40s to NS
12.3 PBS KIINSD2 IPTV World 30s to NS
20.1 CW KWKB 30s to NS
20.2 CW KWKB20- 20s to NS
22.1 RTN KWWF TBA 20s to NS
22.2 RTN KWWFD2 TBA 20s to NS
28.1 FOX KFXA-DT FOX28 40s
28.2 TCN the country network 40s
32.1 PBS KRINHD IPTV 60s
32.2 PBS KRINSD1 IPTV learns 60s
32.3 PBS KRINSD2 IPTV world 60s
48.1 ION KPXR 70s
48.2 KPXR-2 qubo 70s
48.3 KPXR Ion LIFE 70s
12.1 same as 32.1
12.2 same as 32.2
12.3 same as 32.3
22.1 same as 22.2
got to give my 1 finger an tired old eyes a brake
more ?s later
Marty
Old 1-Jan-2012, 6:48 PM   #15
I chose to ground my mast and coax, each as separate steps. The ground wires come together only at the electrical service ground. http://forum.tvfool.com/showthread.php?t=901
Have you tried pointing the antenna at KWKB? If reception of their signal is of interest to you, you may find you'll still receive the stronger signals through the back of the antenna.
Old 1-Jan-2012, 9:58 PM   #16
marty slater
Will work on grounding next couple of days 30 to 40 miles per hour today.
The ANT is mounted with the kit on the gable end of the garage. I think it worked out good it put the ANT about 1' over the ridge of the roof the ridge of the roof runs pretty much east west. Set my ANT at 320 like you said earlier
Marty
HAPPY NEW YEAR to you an yours
Old 2-Jan-2012, 12:12 AM   #17
rickcain
If you can still find them I highly recommend the Zenith DTT-901. The Digital Streams have heat problems and tend to burn themselves up, plus their sensitivity is horrible.
Old 4-Jan-2012, 7:34 PM   #18
marty slater
wind died out going to do some more grounding
while i am up there going to turn the ANT about 180
an point it at KWKB at about 148
Marty
Old 5-Jan-2012, 4:45 PM   #19
marty slater
;all Right then GroundedMyMast
turned the Ant about 180 to point at 148
didn't really help any thing ran the signal test
with just about the same results
so i am thinking this is what i get for what i got
THANK YOU for your time an assistance
Marty
1 MORE CABLE BILL an i will GO IN to pay it OFF!!!!!!!!!!!!
