Old 19-Nov-2011, 1:40 PM   #1
Bluewizard
Chantilly, VA - Reception Help
Hello All,
I have been OTA for a while now and think I should have a way to get some better reception than what I do.
Here is my tvfool report:
http://www.tvfool.com/?option=com_wr...ec12d25256e9e4
I have a problem where the Broadcast stations are on the other side of a hill with townhouses on them. So I have to point my antenna right at the hill and well needless to say this does not have the best of receptions. The Hill starts its slope up about 20-30 feet from the back of the house.
I have a Winegard 7084P and a channelmaster pre-amp. The other problem is that it can be windy and it moves my antenna so it goes from a touchy ok for the channels to well not so much.
I am not opposed to replacing all/part of the setup to actually get all the local channels. Right now I don't get channel 4 (NBC so it looks like 48), 9, 50, 20 (35) is so so.
These seem to come in ok, 5 (36), 7, 32 (WHUT), 30, 66 (34 Most of the time)
I would have expected things to work better than what they do. I have RG6 Coax running down the side of the house from the antenna to inside.
Any suggestions would be appreciated.
Bluewizard is offline   Reply With Quote
Old 23-Nov-2011, 7:39 PM   #2
Jammer
How high is your antenna from the ground? Can you re-run the report at that height and at, say, 10' and 20' higher? Any way you can get more height if that might solve it?
7 and 9 broadcast from the same location at almost the same power and elevation so it's puzzling why you'd get one and not the other. Might just be in a bad spot, you could try moving the antenna 10' or 20' away from it's present location and see if that helps.
Jammer is offline   Reply With Quote
Old 23-Nov-2011, 8:22 PM   #3
Did you find any of the suggestions from the "Digital Home Forum" to be useful?
