Old 8-Nov-2011, 8:17 PM   #1
oldjake135
what antenna would be best for me
http://www.tvfool.com/?option=com_wr...4bbac3990ab330 thanks for any help i am in Beaverton ont. Canada
oldjake135 is offline   Reply With Quote
Old 9-Nov-2011, 1:20 AM   #2
It looks as if there is limited digital deployment in your area. You would benefit from a large all channel antenna such as the Winegard HD8200U. A low noise preamp such as the Winegard HDP-269 or Antennas Direct CPA-19 would be needed to 'push' the signal down the coax.
Your report indicates 50 feet AGL as the mounting height for the antenna. Do you already have a tower?
Old 9-Nov-2011, 3:41 AM   #3
oldjake135
best antenna
yes i have a 50 ft, tower , 40 plus 10 ft pipe
Old 9-Nov-2011, 6:32 AM   #4
be236
Seems you're only about 90 km away from Toronto towers, so you should be having strong NM values... guess there must be lots of hills and trees inbetween...
Old 9-Nov-2011, 2:56 PM   #5
oldjake135
signal
i get all the local channels, the american ones come and go i put up a 8 bay antenna was wondering if i changed it to a ccs 1843 antennna craft for deepfring area might help?
Old 9-Nov-2011, 4:11 PM   #6
The HD8200U has a bit more gain than the CCS-1843. Both would provide coverage of VHF frequencies the 8-bay does not.
I think you are too far from the US stations to get 100% reliable reception. Expect the weather and sun-spot activity to affect the signal propagation of all of those south of the border signals.
Old 9-Nov-2011, 6:58 PM   #7
oldjake135
antenna
thanks for getting back to me , i kind of thought the same
