Go Back   TV Fool > Special Forums > General Site Feedback / Discussion
Old 23-Oct-2011, 6:49 PM   #1
frisco
Channels beyond 2-69
If I have an antenna that is rated to receive channels 2-69, but my Channel Master PAL 7000 just brought in channels 72, 74, 76, and 78, will they transmit through onto TV?
frisco is offline   Reply With Quote
Old 23-Oct-2011, 8:41 PM   #2
Sounds like the DVR is in CABLE mode, not AIR. Cable is distributed using more frequencies than OTA, so the numbering scheme is different.
Old 24-Oct-2011, 1:34 AM   #3
MisterMe
The ChannelMaster CM-7000PAL DVR receives digital over-the-air broadcast TV transmissions exclusively. It does not receive cablecasts. Therefore, it has no cable mode. This leaves the OP's receipt of channels above 69 as a mystery. Perhaps, a greater mystery is why are his channels not 72.1, 74.1, 76.1, and 78.1. Also a mystery is why is he asking the question in the first place. If the DVR is being used as a receiver, then it is expected to transmit everything that it receives to the TV whether the TV is digital or analog.
Old 24-Oct-2011, 6:23 PM   #4
I have seen similar display when stations moved channels and the DTV PAL needed a number above 69 to place a second instance of the same channel. To resolve the problem you can delete all channels and then rescan, do a double rescan, or a factory reset followed by a rescan.
In other cases stations may be adding a data only subchannel without video or audio PIDs. If that's true for you, how the DTV PAL reacts is hard to predict.
