Old 6-Oct-2011, 7:07 PM   #1
okhipfan
Another Atenna Advice Request
I live in NE Oklahoma and looking at purchasing an antenna for OTA HD instead of DISH service. Unfortunately we are in a small valley area and indoor antennas don't seem to do the trick for all channels. I can get local CBS but not ABC & NBC even though they have similar compass settings.
Here is the TVFool report for my address: http://www.tvfool.com/?option=com_wr...60b51c02f489bb
Any suggestions on a good antenna? We will have 3-4 TVs hooked up to it.
Thanks for any help!
okhipfan is offline   Reply With Quote
Old 6-Oct-2011, 7:35 PM   #2
MisterMe
You have ample signal strength on many channels including your ABC and NBC affiliates. The only thing is that ABC and NBC are Hi-VHF but CBS is UHF. You are picking up the UHF station fine. You need a 7-69 antenna.
Old 6-Oct-2011, 7:39 PM   #3
Reading between the lines a bit, simple and reliable reception of the major networks is your goal... with no rotator to argue over.
A Winegard HD7694P pointed at 80° compass, mounted on the roof or chimney would be my choice. There may be enough power to drive a passive 4-way splitter, I'd try. If needed, an Antennas Direct CPA-19 preamp could be added at the antenna mast.
There will be a few stations that may not be available to you, KTPX-ION being a notable one because it comes at you from an angle for which the antenna has little sensitivity. The group of stations at about 20° compass seem to be religious or spanish language programing based on my limited research.
If you want to receive every possible signal, a different solution can be offered.
Old 6-Oct-2011, 7:42 PM   #4
okhipfan
Sorry for my lack of details, but yes, major networks is our goal with anything else being 'gravy'.
Old 7-Oct-2011, 2:39 AM   #5
okhipfan
Smile
Let's say for arguments sake I wanted to get as many channels as possible. I'll go with the Winegard stated for my ABC,NBC,CBS. What are the other options for most possible channels.
This is a huge help. Thanks for the replies.
Old 7-Oct-2011, 7:41 AM   #6
Going after all possible.
Because you have multiple TV's, I'd suggest a second antenna. A Winegard HD7698P mounted on a rotator. This second antenna could serve one set, or both antennas could be cabled to each set, each equipped with an A/B switch to allow selection of the fixed or rotatable antenna as desired. Only one location would have rotator control.
With A/B or A/B/C switching you could opt for two or three fixed aim antennas.
If you are inclined to use home theater PC technology, take a look at this thread: http://forum.tvfool.com/showthread.php?t=820
Old 7-Oct-2011, 9:06 AM   #7
I recommend a Channel Master CM3000A antenna and a CM 3414 four way distribution amplifier. Please note that omnidirectional antennas are not 100 % omnidirectional and might need to be turned by hand to find a sweet spot that receives the tv stations from the different directions and then tighten the clamps. Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com , http://www.channelmasterstore.com
Old 8-Oct-2011, 8:14 AM   #8
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html
Old 8-Oct-2011, 4:39 PM   #9
Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695. Here are some tv guides , http://www.zap2it.com , http://www.titantv.com , http://television.aol.com , http://tv.yahoo.com , http://tv.entertainment.excite.com , http://tvzap.com. Most tv guides show the channels as virtual channels. Also please note that digital tv stations can begin broadcasting at any time and digital tv channels can be added to tv stations at any time with out prior notice , so is a good idea to scan for new digital tv channels.
