2-Oct-2011, 11:08 PM
#1
Need an antenna with new room
Hey guys, I could use a little help. I have been getting my basic network channels with an RCA amplified indoor antenna (mostly) but I have a new addition and the foil on the insulation makes for bad reception. I actually brought the TV and antenna into room and into 2nd floor and attic but no good. I figured I'd go with an outdoor antenna on the roof (aprox 20'). Here is my TV fool analysis
http://www.tvfool.com/?option=com_wr...60b5a4d1906cdf
I'm just looking for the basic channels (the top 7). It's just the 1 TV with no splitters and preferably no amp. The room broke the bank, so the cheaper the better. Thanks for any help you can give me.
3-Oct-2011, 2:59 PM
#3
Thanks for the links, John. I thought I was going to need a big yagi. My wife was willing to put up with it, but she'll be pleased with the clearstream's small footprint. And it has the J-mount. Thank you.
3-Oct-2011, 8:39 PM
#4
TV Reception Maven
Don't expect the Clearstream 2 to get WBRE and WYOU reliably: it's strictly a UHF antenna, and any VHF reception you get from it would be incidental: A better choice, and cheaper, too, would be to use an AntennaCraft HBU-22
3-Oct-2011, 8:50 PM
#5
It's the C2v that was suggested, not the original C2. The "v" version is new as of mid-August.
3-Oct-2011, 11:23 PM
#6
It's the C2V UHF/VHF high band antenna. As always , when a antenna is installed and is pointed at about the recommended degrees magnetic compass , As an example , if one is standing behind the antenna , the antenna is turned to the left and right to find a place that produces the strongest reception of the stations/channels that are being received. You are shooting for the stations from 294 to 228 degree magnetic compass.
4-Oct-2011, 12:23 AM
#7
As all ways , tv antennas receive the best when the tv antenna has elbow room , do not aim the antenna in to the roof of the house , do not aim the antenna in to a chimney , Tv antennas receive the best when the tv antenna has a clear shot at the transmitting antennas , the more that is in the way the less the reception will be.
4-Oct-2011, 12:45 AM
#8
Just trees in the way
Thanks for the tips. I have a couple of big trees about 20'-30' in the direction of the majority of transmitters (nothing in the direction of the 2 transmitters 4 miles away). I'm assuming that shouldn't be a problem since my indoor amplified RCA pulls them in. The indoor antenna sits on the 2nd floor and I was planning on mounting the new antenna on the roof (almost directly above where the indoor one is now).
4-Oct-2011, 2:38 AM
#9
4-Oct-2011, 2:08 PM
#10
Originally Posted by John Candle
The CV2 may work, but I would aim it at about 230°.
A better choice is adding a Y5-7-13 aimed at 216° to a C-2 using a UVSJ.
4-Oct-2011, 8:35 PM
#11
This TVFool is as close to a "perfect" match for the C2v as I've seen. I've seen it work perfectly in far, far worse scenarios.
BTW, I just noticed that our web guy got the formal datasheet for the C2v posted to our website. It's available at http://www.antennasdirect.com/cmss_f...%2BVHF-TDS.pdf
4-Oct-2011, 11:53 PM
#12
The UHF portion will probably have trouble if aimed at 60 degrees. Use 230 instead.
5-Oct-2011, 10:18 PM
#14
TV Reception Maven
$120.00 for an antenna when a $30.00 antenna will do? What price is it to be paid to be inconspicuous?
6-Oct-2011, 3:13 AM
#15
Cheap is good
I'm all for cheap Tigerbangs. I was looking for the cheapest setup that would get me the basic channels. The reason I posted here was that I wanted to avoid either overpaying or getting garbage that didn't do the job. Thanks for the advice.
8-Oct-2011, 5:00 PM
#16
Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool/showthread.php?t=695. Here are some tv guides , http://www.zap2it.com , http://www.titantv.com , http://tv.yahoo.com , http://tv.entertainment.excite.com , http://www.tvzap.com , http://television.aol.com. Most channels are listed as , virtual channels. Also please note that digital tv stations and digital tv channels can begin digital broadcast at any time with out prior notice so is a good idea to scan for digital channels from time to time.
8-Oct-2011, 5:01 PM
#17
Looking for the cheap , well cheap is cheap.
8-Oct-2011, 5:38 PM
#18
8-Oct-2011, 5:44 PM
#19
8-Oct-2011, 9:20 PM
#20
TV Reception Maven
The AntennaCraft HBU-22 is an inexpensive, well-made antenna that is not a gimmick rip-off: It's a conventional antenna that is well=proved, and more than adequate for your needs. There is nothing wrong with AntennasDirect products, either, but they do tend to charge a lot of money when simple and inexpensive solutions exist. Their products feature compact size and more pleasing design than conventional antennas. The question is whether or not the aesthetics of their products are worth the 200-300% premium that you pay for their style. Some of their products, like the AntennasDirect XG-91 are personal favporites of mine for deep-fringe reception, but other products that they make like their V10 and V21 VHF-UHF antennas are inferior in quality and value to products of other manufacturers.
