Old 25-Sep-2011, 9:01 PM   #1
cep1001
Antenna Recommendations
Hello all I'm hoping that someone can help me out with a recommendation for an Antenna. My husband currently working a couple of hours from home and is renting a mobile home would like to be able to watch a little TV after work. Set top antenna only picks up a couple of stations this job will probably last a couple of years and we are renting from a friend so I thought we might by a roof top antenna all suggestions welcome if I got this right here is my map http://www.tvfool.com/?option=com_wr...60b5f6b16fb380 thanks all!
cep1001 is offline   Reply With Quote
Old 27-Sep-2011, 4:12 AM   #2
An easy reception situation with lots of channels to receive. I recommend a Winegard HD7694P antenna aimed at about 141 degree magnetic compass. Here are some antenna mounts that usually work well with mobile homes , http://www.ronard.com/100204.html , the pictures show these stand off mounts close together for the purpose of demonstration , it is best to mount them further apart to provide more stability to the mast and antenna. Here is another mount , http://www.ronard.com/34424560.html
Old 27-Sep-2011, 4:24 AM   #3
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
Old 27-Sep-2011, 11:03 AM   #4
cep1001
Thank you for taking the time to help me out, I will check out your recommendations. TIA
Old 27-Sep-2011, 11:52 PM   #5
Here are a couple more mounts , http://www.ronard.com/909911.html , http://www.ronard.com/ychim.html
