Old 5-Sep-2011, 11:11 PM   #1
rvafas82
your thoughts
http://www.tvfool.com/?option=com_wr...8387f36950c133
which antenna do you think would work best for me? i will be performing an attic install, which will place the antenna around 30 feet.
Winegard HD 7696P
Antennas Direct DB4
Antennacraft HDTV/UHF 4 Bay Antenna
rvafas82 is offline   Reply With Quote
Old 6-Sep-2011, 7:16 AM   #2
http://forum.tvfool.com/showthread.php?t=2086
Old 6-Sep-2011, 4:07 PM   #3
John's advise in your earlier thread is correct.
All of the stations in the green section of your TVFR should be viewable with a U4000 as John has suggested. The aim point is not 'cast in stone', but is a starting point... pan left and right to optimize, then tighten the clamps.
In the unlikely event that you have some trouble with channel 12, addition of a Y5713 and a UVSJ would be the backup plan... I don't think you'll need that option.
Stations in the red and gray sections of your TVFR would be challenging because they are weak signals and generally subject to adjacent and co-channel interference. If you want to get into the DX hobby, then your antenna system would be much different.
