Old 28-Aug-2011, 4:52 AM   #1
jnkweaver
Antenna Recommendation
I am looking for a rooftop antenna mounted on my single dwelling two-story house. It would only need to pick up the green and yellow in the UHF band from mag heading of 244 to 275. I was hoping to use the existing coax cable that presently runs cable to the tvs using some amplified splitters. We can skip the PBS station WSIU that is High VHF since KETC is UHF and in the basic heading. Which antennas would you recommend
http://www.tvfool.com/?option=com_wr...9e744aacfbc1c1
jnkweaver is offline   Reply With Quote
Old 28-Aug-2011, 7:25 AM   #2
Old 28-Aug-2011, 4:12 PM   #3
Any of the 4-bay panel antennas. (DB-4, U4000, CM4221... etc.)
Old 28-Aug-2011, 5:18 PM   #4
jnkweaver
TVs connected
Counting the 2 computers with tv tuner cards I have 7 televisions connected. 3 are in the basement so an indoor is not as practical not to mention I am sure it is cheaper to get one outdoor antenna then 7 indoor.
Old 28-Aug-2011, 9:42 PM   #5
A CM3418 distribution amp will help feed all those tuners.
Old 29-Aug-2011, 4:01 AM   #6
jnkweaver
Amp
I have something very similar to that already. I will have to check the stats to see if that one is better.
Old 29-Aug-2011, 5:10 AM   #7
No point spending money on a DA unless your existing amp overloads.
