Old 28-Aug-2011, 1:45 AM   #1
musky
Question Only 12 digital channels with 8 bay
Im in st.catharines ont,today i put up a 8bay antenna and after moving it mulyipal times i can only pick up 12 digital channels and cant seem to get 11.1 chch either the antennea is on the top of my house about 6 feet up from my chimminy.
Channel master (CM-4228HD) 8 Bay EXTREMEtenna- HDTV Antenna
musky is offline   Reply With Quote
Old 28-Aug-2011, 3:10 AM   #2
The 4228 is a UHF antenna & while it can sometimes do OK on VHF, it is purely incidental & very unpredicatable.
Receiving the weak CHCH signal reliably will require a real VHF antenna like the Antennacraft Y5-7-13 or Winegard YA-1713.
Old 28-Aug-2011, 5:20 AM   #3
MisterMe
You have 15 stations that are line-of-sight (LOS). However, they are all UHF as is every other station--both Canadian and US--that you can expect to receive. My first suggestion is to check the listed stations after you redo this radar plot with your exact address. I have to wonder--do you have a stand of trees or some other local obstruction blocking your antenna?
Old 28-Aug-2011, 7:57 AM   #4
It looks like musky has many other past posts on this same reception situation. If this is a different reception situation or the same reception situation it is time to make a new radar plot.
Old 28-Aug-2011, 7:16 PM   #5
musky
no its a different setup all togeather....so i rescanned this morning and got 20 digital channels?do they turn off some channels a night?
Old 28-Aug-2011, 8:00 PM   #6
If there is no radar chart for this different reception situation , then need to make a radar chart with exact address and expexted antenna height. http://forum.tvfool.com/showthread.php?t=4 . Is this a , house , condo , apt. , mobile home , motor home , or etc ?? How many Tv's are/will be connected??
Old 28-Aug-2011, 8:38 PM   #7
musky
its a house antennea is about 25 feet up from the ground..at night i lose some channels do they turn some off.
Old 29-Aug-2011, 12:15 AM   #8
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You are going to have to re-scan almost every day for the next two weeks as more Canadian stations make the transition from analog to digital. The transition will be complete shortly, but expect that some stations will straggle and may miss the August 31 deadline.
Old 29-Aug-2011, 2:45 AM   #9
musky
ok thanks.........because i am losing channels on a daily bases.
