Old 18-Aug-2011, 6:00 PM   #1
kurtbwn
clearstream 4
form clarksville, tn
35 mines from nashville towers and
i just want the uhf channels
tv fool plot:
http://www.tvfool.com/?option=com_wr...9e74f731537034
I was thinking of installing a hd7698 and the hdp269 amp
as recommended by this forum.(thanks all)
but I came across the antenna direct's clearstream 4
http://www.antennasdirect.com/store/...V-antenna.html
what are your thoughts on this antenna
i have never seen an antenna like this one
or have i seen one in my town
most of the time i have only seen large combo type antennas
this antenna sure look a lot simpler to install
with a j mast
guys i am 68 and don't want to mess around on the roof
with a roof or eves mount
a j mast on side of my house would be better for me (see house)
if not this antenna how about a db8 or a db4
http://www.antennasdirect.com/store/DB8_HD_Antenna.html
i thank you for your help
i hate to install a huge one if i don't have to
i just want the uhf chan's (2,5,17,30,58) is fine for me
my current antenna believe it or not is a Philips MANT940 UHF
i get (2,5,17) ant 50 % signal strength
kurt b.
kurtbwn is offline   Reply With Quote
Old 18-Aug-2011, 8:32 PM   #2
Given your interest in UHF only, the CS-4 will do quite well for you. It may look different but it is very similar to the DB-4 electrically. Don't be surprised if you see the high VHF signals as well. Mount it facing SE.
Old 18-Aug-2011, 8:53 PM   #3
I agree with GUM. The Clear Stream 4 should work fine. Mount the antenna facing S/E at about 131 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Avoid pointing the antenna through trees if you can. Tree leaves absorb UHF signals more the VHF signals.
Old 13-Sep-2011, 6:35 PM   #4
kurtbwn
clearstream 5
what are your opinions on combining a clearstream 4 and clearstream 5
with their uhf / vhf combiner and then their
CPA-19 pre-amplifier
i don't care to much about the vhf (2 channels 8,4)
but was wondering if it would work
if i am going to blow $200.00 on the kit with the amp
i may as well go all the way
i was wondering because i could use 2 30 inch j masts
on the side of the garage it would make installing easy for me
thanks all
i never knew that their was so much to know to get a tv sigal
kurt b.
http://www.tvfool.com/?option=com_wr...14f3b508de05d7
Old 14-Sep-2011, 6:05 AM   #5
Yes it will work , connect the CPA-19 to the output of the UVSJ that comes with the C5. The tv stations are there , may as well receive them. Digital tv stations are adding new digital sub channels. You might not be interested in the programing now but when a new channel is added then you might like that one even though it's a VHF channel. There really is not that much to receiving tv with a tv antenna. What makes the situation more then it really is , is dicing the situation up into smaller parts , when going for the whole is easyer.
Old 14-Sep-2011, 3:27 PM   #6
Be careful, WSMV is on VHF channel 10 and it's not LOS.
The best UHF only antenna for channel 10 VHF reception is the Channel Master 4228HD
