Hi there.
I am looking for an antenna recommendation that has to be indoor and temporary since I’m renting the first floor of a two-story house. Access to the attic and/or roof is not possible.
 http://www.tvfool.com/?option=com_wr...3e47716fec4754
Currently I’m using a Zinwell Zat-970A digital to analog converter box and RCA multi-directional digital flat amplified antenna with one tv. The converter box is new. This antenna has been around since the analog/digital conversion. I recently bought and returned a RCA ANT121 - TV / radio antenna - Indoor and RCA ANT1400 Multi-Directional Digital Flat Passive Home Theater Antenna b/c I wasn’t getting any additional stations.
ABC (15.1) comes in well and CBS (3.1) usually comes in fine. Depending on the weather, NBC (17.1) is sometimes available. Ideally, I would also like to get FOX (27.1) and PBS (12.1).
I am looking at the following antennas per Amazon (the others were all from a Best Buy store).
- Terk HDTVa Indoor Amplified High-Definition Antenna for Off-Air HDTV Reception
- Winegard SS-3000 Amplified Indoor UHF/VHF Antenna
What do you recommend? Any other suggestions?
Thank you!
