Old 13-Jun-2011, 12:57 AM   #1
Rob
Starting out
I have an existing antenna that i had when I had (look tv) its sits at the peak of my roof on my house. Can I use this as an antenna to get channels or do i need a diffrent type of antenna. As far as setting up the tv to recieve channels I am un-aware of what I need. In fact I am still with starchoice and also have a dish from them that is located on the back of my house which I believe that both dishes are facing south. The location of my house is 95 mondavi road L4H 1L8. please help me get started as i am very new to this.
Rob is offline   Reply With Quote
Old 13-Jun-2011, 1:47 AM   #2
What city and what territory in Canada?? Is this the location?? 95 Mondavi Road , Woodbridge , ON. , http://www.tvfool.com/?option=com_wr...001b90f5265956
Old 13-Jun-2011, 7:15 AM   #3
If the address is correct then you have a good location to receive the Canada Digital Broadcast Tv Stations and the American Digital Broadcast Tv Stations. I recommend the Winegard HD7698P antenna , http://www.canadapost.ca/shopper/ite...H-BAND-HD7698P. To point the antenna , start with the antenna pointed at about 170 degree magnetic compass and turn the antenna to the left and right for the strongest reception of the American stations. Here is how to point Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html , The HD7698P antenna will supply signal to 1 or 2 Tv's. How many Tv's will be connected??
Old 13-Jun-2011, 7:21 AM   #4
Mount the antenna on a Strong and Sturdy mount , tripod mount , chimney mount , peak of the roof eave mount. Use RG-6 coax cable through out the antenna system , both outside the house and inside the house. How many Tv's will be connected??
Old 13-Jun-2011, 8:09 AM   #5
Here are pictures of mounts , http://www.summitsource.com/images/products/ANRT36.jpg , http://www.eham.net/libraries/downlo..._&Itemid=A.jpg notice the wide spacing of the straps - this makes the mast and antenna strong and stable. , http://www.sadoun.com/Sat/Products/Perfect/PVEM1.gif . Buy mounts and etc. at http://www.saveandreplay.com , Channel Master tripod CM3092 , Chimney mount CM9067 , Eave mount CM9030
Old 13-Jun-2011, 8:17 AM   #6
How many Tv's will be connected?? Here is more information about Tv reception , http://www.tvtechnology.com/article/105462 , http://www.tvtechnology.com/article/117022 http://www.trentondistributors.com , http://www.digitalhome.ca/forum , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm . How many Tv's will be connected.
Old 13-Jun-2011, 8:54 AM   #7
Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695. REAL , Virtual , Analog , is the same for both the USA and Canada , the difference is the dates. How many Tv's will be connected??
